Forum Home Forum Home > Hints & Tips > 400
  New Posts New Posts RSS Feed - Bimini on a 400?
Bimini on a 400?
tsjames View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tsjames Quote  Post ReplyReply Direct Link To This Post Topic: Bimini on a 400?
    Posted: 16 October 2007 at 22:59
My new 400e is due to arrive in Southern California any day now!  Has anybody successfully installed a bimini on a 400 and if so do you have photos?  A collapsible or removable setup would be ideal as I'd only use it during multi-day Summer cruises.
Thanks,
TJ
svrocinante View Drop Down
Lieutenant Commander
Post Options Post Options   Thanks (0) Thanks(0)   Quote svrocinante Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2007 at 18:52
Sure, here is one picture... if interested, I can probably dig up a few more.
Regards,
Carlos & Maria
SV Rocinante
you may not be able to control the wind,
but you can adjust your sails
My Internet Doorman-The easiest way to keep porn out of your home...Guaranteed!™
Johan Hackman View Drop Down
Admiral of the Fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johan Hackman Quote  Post ReplyReply Direct Link To This Post Posted: 17 October 2007 at 22:08
That's a wonderful photo of your beatiful boat! I like the way the name is printed, too. It seems like it's the cold time of year, is it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote svrocinante Quote  Post ReplyReply Direct Link To This Post Posted: 18 October 2007 at 03:33
Thank you...
Yes, it was taken this past December 29th in Elizabeth City, North Carolina.  Great little town with 48hr complimentary dockage and the “Rose Buddies” see link for more info http://www.elizcity.com/rose/
silversailor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote silversailor Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2007 at 00:09
Carlos and Maria,  I notice that you don't have the front "bra" piece on your saildrop.  I've not found a way to put that font piece on and keep the lazy jack line which are attached to the front part of the sail tight.  Have you?
Silversailor
South Haven, MI USA
S/V Legacy
2010 Andrews 28
Post Options Post Options   Thanks (0) Thanks(0)   Quote svrocinante Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2007 at 02:04
Quite honestly, we haven't even tried... removed the darn thing when we left Annapolis and never put it back on...
Muscadet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Muscadet Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2007 at 10:15
The problem with the front lazy jack lines and the cover were the subject of a (very) much earlier  thread. If the lines are slack enough you can force them into the cover but this presents two problems.
1) It causes chafe on the cover.
2) It places the lazy jack lines next to the mast where they make a slapping noise when the wind gets up.
My solution on my 312 is to leave the cover off while I am using the boat. When I leave the boat I move the front lazy jack lines back to the second line position and then I can fit the cover in front of them. Before sailing again the lines have to be moved back to the forward position. It doesn't take very long to do but I would like to find a way to re-route them so this won't be necessary - any suggestions would be gratefully received! LOL
Alan
Alain & Anne View Drop Down
Rear Admiral
Rear Admiral
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alain & Anne Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2007 at 10:57
This is the bimini made by NV Equipment for our 430.
As you can see we have no trouble to fix the front cover.... except the fact that we need to climb the mast as the the top-traveler is 3.10m high!!
Edited by Alain & Anne - 19 October 2007 at 11:05
UHAMBO 430e#004
OCC
Our blog: www.uhambo.fr
hull # 120 View Drop Down
Lieutenant
Lieutenant
Post Options Post Options   Thanks (0) Thanks(0)   Quote hull # 120 Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2007 at 13:27
I have attached snap clips to the lazy jack lines which are closest to the mast.    When I am done sailing, i just move them aft and attach them to a loop i put in on the next lazy jack attachment spot.    This creates room to put the "bra" on without being encumbered by the lazy jack line.    It only takes a few seconds to move the lines around this way.
Jon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Muscadet Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2007 at 15:43
Brilliant! I knew someone would come up with a solution!Thanks Jon.
Alan
This page was generated in 0.088 seconds.
