  New Posts New Posts RSS Feed - I got to try my new storm jib today
 Post Reply Post Reply Page  123 4>
Johan Hackman View Drop Down
Admiral of the Fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johan Hackman Quote  Post ReplyReply Direct Link To This Post Topic: I got to try my new storm jib today
    Posted: 03 June 2009 at 21:41
Please note that since I wrote this post I have tested this sail under conditions near the conditions it was designed for. I have to warn you all that it is a dangerous sail. If you manage to hoist it in strong winds (which will be difficult) you may not be able to get it down. To wrap a sail around a furled head sail in strong winds is a bad idea. I do NOT recommend it and I hope I have not persuaded anyone to get a similar sail by advertising it the way I do below.
I recently purchased a heavy wind sail that would make up for the situations where the selftacker offers too great a sail area. It is simply wrapped around the furled jib and the two halves are held together by the selftacker's sheet. The sail area is reduced to approximately 9 squaremetres.
Today was fairly windy but the conditions didn't really call for a smaller sail but I thought it was a good opportunity to try it anyway.
Edited by Johan Hackman - 01 August 2012 at 20:52
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johan Hackman Quote  Post ReplyReply Direct Link To This Post Posted: 03 June 2009 at 21:46
holby View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote holby Quote  Post ReplyReply Direct Link To This Post Posted: 04 June 2009 at 01:15
Johan nice pictures but who was using the hose pipe on the second one?LOLLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johan Hackman Quote  Post ReplyReply Direct Link To This Post Posted: 04 June 2009 at 08:06
King Neptune, of course.
Edited by Johan Hackman - 06 June 2009 at 20:32
Post Options Post Options   Thanks (0) Thanks(0)   Quote holby Quote  Post ReplyReply Direct Link To This Post Posted: 04 June 2009 at 08:55
You were lucky to have him handy to provide the water spray.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johan Hackman Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2012 at 20:53
Please note that since I started this thread I have tested this sail under conditions near the conditions it was designed for. I have to warn you all that it is a dangerous sail. If you manage to hoist it in strong winds (which in itself will be difficult) you may not be able to get it down. To wrap a sail around a furled head sail in strong winds is a bad idea. I do NOT recommend it and I hope I have not persuaded anyone to get a similar sail.
panos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote panos Quote  Post ReplyReply Direct Link To This Post Posted: 01 August 2012 at 23:26
What exactly happened? You don't seem particularly happy!
I really hope your story had a happy end.
Panos
Hanse 630e - selling her -
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johan Hackman Quote  Post ReplyReply Direct Link To This Post Posted: 02 August 2012 at 00:10
I am not sure I can tell you exactly what went wrong but I'll give it a try.
The sail is stored in a bag that you put around the forestay. When in position you tie both clews together by means of the jib sheet (two clews as the sail is made of two halves), attach the head to a spin halyard and tie the tack line to the furling drum. When this is finished you open the bag and hoist the sail. That is the idea.
I must have made a mistake when I packed the bag. The sail somehow did not wrap around the furled jib but flew from the tack, the head and the jib sheet - like a gennaker, if that makes the picture clearer. It was then I realised that I could not correct my mistake by bringing the sail down. The design with the wrapped sail means that the sail squeezes around the furled jib which in a strong wind means that it is impossible to drop. Instead it was flogging like mad and for a while I feared it would destroy the entire rig. It was only after an hour, standing on the pulpit with the bow bouncing in the waves that I managed to pull it down with a boat's hook!
Now, if you are new to sailing for example a spinnaker it is wise to learn to use it in light winds and only then start to use it in heavier airs. With a strong-wind sail it is the opposite way round. If you learn to use it in light winds (like I did and told about in previous posts in this thread) you are NOT learning to use it in strong winds. You fool yourself by thinking so. You have to rely on the sail maker that they have tried and tested the sail for you.
This little experiment made me realise that you will not be able to bring the sail down even if it is set up correctly. If you think about it, people on this forum complain about their mains being hard to hoist and drop in a dedicated groove on the mast - how hard will it not be to hoist and drop a sail that is wrapped another sail when there is a strong wind? I spinnaker sail that goes wrong can always be corrected by dropping the sail in the water. All you do is let go of the halyard. Letting go of the halyard of a sail wrapped around another sail is not going to bring it down.
A sail that is flogging and you cannot rid yourself of is dangerous.
Edited by Johan Hackman - 02 August 2012 at 07:24
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johan Hackman Quote  Post ReplyReply Direct Link To This Post Posted: 02 August 2012 at 00:14
The story has a happy end in that I am never going to use this sail again.
Rubato View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rubato Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2012 at 21:38
Johan, sounds like quite the struggle and one that qualifies as "experience". :)  I wonder if it would have been easier with a line attached to the head that could be used to help pull it down when needed. The other end of the line could be tied off at the tack perhaps....  just a thought...
Hanse 400e, #168
This page was generated in 0.120 seconds.
