Welcome to myHanse.com the forum for Hanse Yachts owners throughout the world. |
Active Topics Memberlist Calendar Search |
| 350 | |
| Author | Message |
Gran Onada
Commander
Joined: 14 November 2008 Location: Spain Online Status: Offline Posts: 89 |
![]() Topic: Genoa CarsPosted: 08 April 2010 at 22:15 |
I am thinking on fitting the genoa cars, which I did not order from factory.
What size are for Lewmar's? number 1?
Any other recomendation besides Lewmar?
Gran Onada
IP Logged |
shaukaas
Joined: 04 August 2008 Online Status: Offline Posts: 168 |
![]() Posted: 09 April 2010 at 13:55 |
I have just orderred, and received, Genoa cars from Lewmar.
The tracks on my 2008 built 320 are size 1. But be aware that there is not enough room between the tracks and the windows for a "TB" (Torlon Balls) car. I therefore had to buy the "SL" (Sliding Rod) cars giving less performance/more friction with the cars strained. I bought this combination: 29441513 29471035 + a set of clam cleats to be mounted somewhere near the cockpit. 29104104 29104100 Pictures of the installation will probably be publish in the 320 section when complete within the next few weeks... |
S/Y Nadun - Hanse 320#171
LG3600 - NOR13510 |
IP Logged |
Gran Onada
Commander
![]() Posted: 10 April 2010 at 18:59 |
Originally posted by shaukaas
I have just orderred, and received, Genoa cars from Lewmar. The tracks on my 2008 built 320 are size 1. But be aware that there is not enough room between the tracks and the windows for a "TB" (Torlon Balls) car. I therefore had to buy the "SL" (Sliding Rod) cars giving less performance/more friction with the cars strained. I bought this combination: 29441513 29471035 + a set of clam cleats to be mounted somewhere near the cockpit. 29104104 29104100 Pictures of the installation will probably be publish in the 320 section when complete within the next few weeks... Thanks for your info it does help much.
I just went to the boat and seen that I also need size 1 and have the same problem I only can use the SL. There is only between 1.5 to 2.5 cm from the rails to the windows.
Do you have picture to see how do I have to install them?
IP Logged |
bjoris
Joined: 11 August 2007 Location: Norway Online Status: Offline Posts: 261 |
![]() Posted: 10 April 2010 at 22:08 |
If you are planning for just a genao 3 (108%) there is a difference between the 320 and the 350. The shrouds on the 350 are closer to the genaotrack. This makes problems sheeting a genao 3 on the 350 without doing anything with the genaotraks... I have after some testing ended with the sheet between the lower and the intermediat/upper shrouds... Not at all good, but better than both inside and outside the shrouds. The best solutions I think is to have inhaul, but I dont have this yet... The point in this case is that with just a genao 3 there is noe much room for sliding the genaocar, it is mostly placed as fare forward possible... to avoid to much pressure on the shrouds... So I just have the size 1 car, nothing else...
Edited by bjoris - 10 April 2010 at 22:09 |
H350#118
www.bjoris.blogspot.com |
IP Logged |
shaukaas
![]() Posted: 26 May 2010 at 15:13 |
Originally posted by shaukaas Pictures of the installation will probably be publish in the 320 section when complete within the next few weeks... The pictures are now published in the 320 section... ![]() |
LG3600 - NOR13510 |
IP Logged |
geoffbell
Joined: 29 July 2010 Location: United Kingdom Online Status: Offline Posts: 7 |
![]() Posted: 29 July 2010 at 19:37 |
Sorry to bother you, but wonder if you can point me in direction of the pictures of your genoa car installation? I have just ordered genoa and want to see best way to set up the cars to bring sheets back into cockpit.
Many thanks
Geoff
IP Logged |
shaukaas
![]() Posted: 30 July 2010 at 15:04 |
LG3600 - NOR13510 |
IP Logged |
geoffbell
![]() Posted: 30 July 2010 at 15:30 |
.......many thanks for the photo's, very much appreciated. Not as simple as I was hoping!
Geoff
IP Logged |
Forum Jump |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
Links : www.hanseyachts.co.uk www.hanseyachts.com www.fjordboats.co.uk www.hansedownunder.com.au www.cobaltboatsuk.com |
