  New Posts New Posts RSS Feed - Webasto overheating problem
samba View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote samba Quote  Post ReplyReply Direct Link To This Post Topic: Webasto overheating problem
    Posted: 15 October 2012 at 19:03
Hi all,
This spring our webasto had cures (again). Now the heater starts and after a few minutes your hear less power in the fan and then it stops with error code 10 (10 blinks, overheating).
I am thinking that the problem might be related to the sharp bend the tube makes when leaving the heater.
How have other 411 owners installed their webasto? Mine is installed in the port back locker.
Samba - Hanse 411 - Bruinisse
Rubato View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rubato Quote  Post ReplyReply Direct Link To This Post Posted: 15 October 2012 at 19:27
Samba,
Do a forum search, you will find a lot of information on this topic already.
Hanse 400e, #168
Bandy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bandy Quote  Post ReplyReply Direct Link To This Post Posted: 16 October 2012 at 12:12
Hi Samba,
i experienced the same 2 weeks ago (it turns autumn in Holland) and it turned out that the cover on top was not entirely closed. on top in the middle section (the light grey coloured section) there is a hatch, if this is not entirely well closed You will get the overheating signal.
Bandy
Stella*Nova View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stella*Nova Quote  Post ReplyReply Direct Link To This Post Posted: 16 October 2012 at 12:14
Its possible that you have a problem with Diesel. Did you check your small filter near the heater pump? If this is blocked it can happen that the heater starts but doesn't get enough Diesel, so after a short time it will stop again.
I had this problem once as my tank was nearly empty. After refilling everything works normal.
Just an idea.
Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote samba Quote  Post ReplyReply Direct Link To This Post Posted: 16 October 2012 at 14:11
Originally posted by Rubato Rubato wrote:
Samba,
I tried to do a search with webasto but it only finds 3 articles. With google search I find a lot more.
Jøvani View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jøvani Quote  Post ReplyReply Direct Link To This Post Posted: 16 October 2012 at 18:48
Hi Samba,
I had this problem last autumn. The heater started slowly and could may be burn for 1 hour or so, but never gave maximum heating. I demounted the heater unit and delivered it for service. They changed the burn chamber unit. I asked to get the unit they changed and it did not look good, completely blocked, filled with coal look alike (don't know the English word, called "koks" in Norwegian). Their advice was to let it burn with max heating before turn it off and never only let it burn for a few minutes only.
Anyway, this season it has worked perfect. The new part was expensive as it is a unit containing the glow function, the diesel nozzle and the burn chamber. One hour service work and the part came to approximately 700 EUR.
The Webasto design is different from the Ebersprecher. To my knowledge on Ebersprecher you can clean the burn camber and replace the other parts as needed.
Hope this can help you to find a solution!
Jøvani
Jøvani Hanse 411 #189
Tønsberg
Norway
Post Options Post Options   Thanks (0) Thanks(0)   Quote samba Quote  Post ReplyReply Direct Link To This Post Posted: 29 October 2012 at 19:46
Hi All,
Our webasto has been repaired. The problem was with the ventilator. It works fine now. We only had 1 overheating error in 5 days. It gave an error of 8 blinks at the end.
I will install two more outlets in the rear cabin so more air can escape
Cheers,
Michiel
This page was generated in 0.062 seconds.
