Forum Home Forum Home > Hints & Tips > 385/388
  New Posts New Posts RSS Feed - Air in the water pump of air condition
Axel View Drop Down
Commander
Commander
Post Options Post Options   Thanks (0) Thanks(0)   Quote Axel Quote  Post ReplyReply Direct Link To This Post Topic: Air in the water pump of air condition
    Posted: 02 July 2017 at 13:30
Hi everybody,
has anybody the inbuild aircondition of Hanse?
My experience is that I have to remove the air in the seawater filter everytime when I start the aircondition. Otherwise it will not work due to a lack of cooling. I have to open 2 of the 4 screws of the transparent lid of the filter. Everytime I have to remove some seawater from the bilge. Do you have an idea how to improve that?
I thought of replacing the lid which is made of glass with one of plastic and made a hole in the middle with a small valve. Opening the valve would remove the air of the system. Any hints or ideas from you?
Greetings from Germany ( in 2 weeks Croatia)
Axel
Hanse 385 #434 Nyanga 2
Wayne's World View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayne's World Quote  Post ReplyReply Direct Link To This Post Posted: 02 July 2017 at 13:52
Axel,
On our air cond cooling pump there is a bleeding valve which is on the upper section of the actual pump. When sailing the system will often loose water and air will be in the pre filter which is down stream from the pump. By opening the bleed valve the air can escape and the pre filter is filled with sea water and the pump with then run correctly. If your pump does not have a bleed valve fitted it probably has a plug in place instead which can be loosened with a spanner to bleed the air out. We put a plastic container under the bleed valve which catches any water that comes through during the bleeding process.
Cruising, currently in the Caribbean and will head across the Pacific early 2024
415 Singapore View Drop Down
Vice Admiral
Vice Admiral
Post Options Post Options   Thanks (0) Thanks(0)   Quote 415 Singapore Quote  Post ReplyReply Direct Link To This Post Posted: 03 July 2017 at 05:35
Hi, we had the same problem, the solution depends on whether you want or are able to run the aircon when sailing. if not just close the stop cock below the filter and then the water cannot drain out when the boat heels over. We haven't had to bleed it since then, but you do have to remember to open the stop cock when you want to turn the aircon back on.
All the best
Paul
Paul - Night Train - 415 #136
AndyS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndyS Quote  Post ReplyReply Direct Link To This Post Posted: 04 July 2017 at 13:56
I agree - we have a little sign that reminds me to close the AC seacock before sailing, and open it back up at port before the AC is turned back on. ALSO: our AC unit was installed about 2 years ago and the condensate drained into the bilge, which was not ideal. We just installed a "Mermaid Condensator" which sucks up the condensate and discharges it into the AC water outlet flow. I liked not needing to drill a new hole and the system works very well.
Andy
Moonraker
River Dunes, NC
Axel View Drop Down
Commander
Commander
Post Options Post Options   Thanks (0) Thanks(0)   Quote Axel Quote  Post ReplyReply Direct Link To This Post Posted: 04 July 2017 at 16:20
I close the sea cock during sailing. But even then there is a small amount of air in the opening of the sea cock which flows into the filter after opening it and stops the pump to work properly. I will have a look at the seawaterpump if there is a bleeding valve.
The original Hanse aircondition has a separate pump to take the condense water to a sea cock at the side of the hull.
Axel
Axel View Drop Down
Commander
Commander
Post Options Post Options   Thanks (0) Thanks(0)   Quote Axel Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2018 at 19:02
I have found a solution: A small seavalve in the lid of the filter. It works pretty good.
Persse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Persse Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 14:38
I also make sure he seacocks are closed when not in use. Yes it is a pain when empty to get the air out. I also sited the water pump lower down as I constantly got air locks in the pump head,
