Nema 2000 bus ‘off’ |
Mark&Catherine
Admiral Joined: 18 January 2013 Location: Turkey Status: Offline Points: 1200 |
Posted: 16 September 2018 at 12:06 |
Hi, returned to the boat and the diagnostics on my NSS 12 say my nema bus is ‘off’. So no instruments showing on any of my displays. Does anyone know why the bus would be off, and how to get it on again?
Mark |
jeb
Captain Joined: 05 May 2014 Location: Sweden Status: Offline Points: 226 |
Check that there is no issue with the automatic fuse for the naw instruments.
Jesper
Hanse 400e |
Konstantin
Captain Joined: 24 August 2014 Status: Offline Points: 223 |
On our 445 the bus was "off" when wind instrument failed on top of the mast. It "jammed" the bus so nothing was coming through. We unplugged everything from the bus just below the electric panel and started plugging it one by one to find what was causing the problem.
Mark&Catherine
Thanks Konstantin. I think I will try that, my radio wasnt working so i unplugged the bus and now it works, so i think there is something blocking the bus as you suggest
Persse
Captain Joined: 21 April 2013 Location: Yorkeys Knob Status: Offline Points: 154 |
Had the same issue, two faulty wind instruments ( replaced under warranty luckily) shut down the system.
Phil O
Mark&Catherine
Hi both, yes its the wind instrument, disconnected it and everything else is back to normal.
Hopefully the new one will last a bit longer than this one! Mark
