Replace Gebo deck hatch (skylight) handles |
skipper
Vice Admiral Joined: 16 February 2008 Location: Sweden Status: Offline Points: 825 |
Posted: 01 October 2013 at 08:43 |
I am going to procure Gebo handles as spare parts but I am not sure which deck hatch model that is mounted on a Hanse 371 from 2002. In the Gebo skylight manual do they list 2 different handles 10 and 15 mm http://www.gebomarineglazing.nl/pdf/Manuel%20luiken%20Engels.pdf 10 mm or 15 mm must be how thich the acrylic is in the deck hatch. The skylight in the forecabin has an alu frame on deck 565 x 565 mm. The skylight in the saloon has a smaller alu frame on deck. When searching for spareparts did I found the Gebo handles on a web-shop but they used the same picture for both left and right handles. I finally order it from a physical shop close to my homeport the image shows how the LEFT HANDLE looks like Edited by skipper - 11 October 2013 at 20:04 |
Skipper Former owner of Hanse 342 2005 (Sparcraft mast, white hull, wheel steering, deep draft keel, short rudder) |
skipper
Hints how to replace handle on a Gebo deck hatch (skylight)
Have received the new handles and have learned during the procurement process that deck hatches up to size 50 x 50 cm do use the spareparts marked as "10 mm". Replace outside closure (vervangen
buitensluiting), the trick is to locate the hidden screw.
1. 2. A paperclip can be used to push down the mechanical blue lock inside the handle
3.
4.
Edited by skipper - 11 October 2013 at 20:11 |
