  New Posts New Posts RSS Feed - Fuel gauge
Fuel gauge
Joey D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joey D Quote  Post ReplyReply Direct Link To This Post Topic: Fuel gauge
    Posted: 26 January 2021 at 13:07
Hello, does anyone happen to have a fix for my fuel gauge always reading 100%?  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fendant Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2021 at 13:09
Yep, it is a cheapo car sensor, notoriously unreliable in a boat.
Replace it with a magnetic rod sensor from Wema or Phlippi.
Post Options Post Options   Thanks (0) Thanks(0)   Quote S&J Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2021 at 18:54
I found mine used to read 100% until it was about half full and then started to get a little more accurate.
StavrosNZ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StavrosNZ Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2021 at 19:49
see my post on replacing the factory automotive units with ultrasonic units that have no moving parts in the tank, these are brilliant.
Stephen
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joey D Quote  Post ReplyReply Direct Link To This Post Posted: 26 January 2021 at 20:04
thank youTongueSmile
Pzucchel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pzucchel Quote  Post ReplyReply Direct Link To This Post Posted: 02 March 2021 at 19:17
it seems i have the same problem on a hanse 588...100% reading all the time. It's not the wurth, i swapped the tanks...
However, it is very complicated to access it (port side) and i don't even know the model to order a new one...does anybody know the precise model for a philippi replacement without changing anything else?
I had already done the water tank, but i can't find on boatoon the precise reference to the fuel tank sensors for the 588...
Hanse588#55
Goat Island View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goat Island Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 17:35
I just purchased a 2019 Hanse 588 and fuel tanks read 100%. What was your fix? Do you have link to parts supplier?
Thanks Johnny
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arcadia Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 20:39
I have not had this problem yet, but I recall on another post, that the problem is that the float can get stuck in the “full” position when the tanks are filled to the top. I will only fill to 90 percent as a rule. The fix was to remove the sender, push the float down, and put a plastic wire tie on the top to keep it from sticking in the future.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goat Island Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 23:09
thank you for this information. I will try the fix.
AndyS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AndyS Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2022 at 16:33
Just as an interesting side note, our fuel gauge on our 385 has always "worked," but shows the inverse of the fuel level. So a 15% reading means that the tank is 85% full. The previous owner said they tried many fixes - including flipping wires, etc - but gave up, so I have always just viewed it as what percentage has been used. And just happy that it kind of worked!
Andy
Moonraker
River Dunes, NC
This page was generated in 0.081 seconds.
