  New Posts New Posts RSS Feed - Air Conditionning flush
Nelson01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nelson01 Quote  Post ReplyReply Direct Link To This Post Topic: Air Conditionning flush
    Posted: 12 October 2021 at 06:57
We are storing the boat for winter.
How are you flushing your A/C system with fresh water?
Marc
Marc
H508#11 UNEVIE
SVZara View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SVZara Quote  Post ReplyReply Direct Link To This Post Posted: 14 October 2021 at 02:06
We run barnacle buster through the system at the end of the season.  We close the through hull and then open up the strainer and pour it in while running all the AC units.  It will clean out the crap in the system.  Then we flush with fresh water using same method.  And lastly we run the antifreeze last and that keeps the system from freezing.
Marc
S/V Zara
2016 Hanse 505, Hull #129
Post Options Post Options   Thanks (0) Thanks(0)   Quote Black Diamond Quote  Post ReplyReply Direct Link To This Post Posted: 19 October 2021 at 12:52
We do the same as Marc.   I rigged up some special hoses that allow drawing from a  bucket and returning to a bucket to help in the process.
415 Singapore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 415 Singapore Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2021 at 06:44
Hi, has anyone done this with the boat in water? If so how?
We have two units running off one central pump, with the outlet valves being in the stern and forward cabins.
I was thinking of closing the inlet and outlet valves and then pumping / sucking out as much water as i can from the strainer, then re-filling with barnacle buster, open the outlet valves a little and run the pump for a short while whilst topping up the strainer. Stop and repeat a few times.
Any advice would as always be much appreciated
Take care
Paul
Paul - Night Train - 415 #136
Post Options Post Options   Thanks (0) Thanks(0)   Quote Black Diamond Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2021 at 23:54
I *ALWAYS* do it with the boat in the water.    That's what the hoses were for.   To disconnect the hose coming from the seacock (in and out) and have it come from/to a bucket.     Making the hoses makes the job easier every fall for winter layup.
FWIW
Post Options Post Options   Thanks (0) Thanks(0)   Quote 415 Singapore Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2021 at 07:10
Hi Rick, many thanks for the reply, I have figured out how to extend the outlet hose so that it comes back to near the strainer / filter. Our inlet is mounted directly to the bottom of the strainer / filter so not possible to disconnect there. So am not sure how to put the water back into the system? If I just take the the top off the strainer / filter and put the hose in there I think I will get water and barnacle buster everywhere?
I saw a Youtube video of a far larger boat and system where they had changed to a special cover for the top of the strainer which had a hose connector in it.
All the best
Paul
Post Options Post Options   Thanks (0) Thanks(0)   Quote Black Diamond Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2021 at 12:00
Ours is a 575, not a 505, so I cannot speak to the specifics of your boat.   On ours,   I disconnect and connect my hoses at the seacock, not the strainer.
I'm sure there are many options, but my experience is that anything that makes the winterizing/commissioning process easier is worth investigating.
Wild View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wild Quote  Post ReplyReply Direct Link To This Post Posted: 21 October 2021 at 19:53
hello
We also have the filter/strainer direct on top of the intake valve.
I have placed a T piece direct after the pump with a valve and a hose to vent the pump when needed.
I connect the hose direct to the fresh watersysteem to rinse the system without running the AC pump.
Till now(11 year) no problem with barnacle in the system.
Belgium
545e#268
Post Options Post Options   Thanks (0) Thanks(0)   Quote 415 Singapore Quote  Post ReplyReply Direct Link To This Post Posted: 26 October 2021 at 13:26
Hi, thanks for the advice, we flushed both systems today. The only complication was getting the 30 mm short hose off between the strainer and the pump. In the end I cut it off and connected a new 1 metre long length to the pump. I had intended to cut this hose back down to the original length, but decided to leave the long hose in as it allows for relatively easy disconnection when the system next needs flushing.
All seems good now the pump seems to run quieter and I was amazed how much black gunge we collected!
All the best
Paul
kipwrite View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kipwrite Quote  Post ReplyReply Direct Link To This Post Posted: 27 October 2021 at 16:58
That AC manifold looks suspect. They are prone to pinhole leaks when they look like that.
This page was generated in 0.106 seconds.
