Fuel gauge |
Post Reply
Page 123> |
| Author | |
Joey D
Joined: 27 June 2018 Location: Florida Status: Offline Points: 82 |
Quote Reply
Topic: Fuel gaugePosted: 26 January 2021 at 13:07 |
Hello, does anyone happen to have a fix for my fuel gauge always reading 100%? Thanks
Fendant
Joined: 03 November 2012 Location: Switzerland Status: Offline Points: 1671 |
Quote Reply
Posted: 26 January 2021 at 13:09 |
Yep, it is a cheapo car sensor, notoriously unreliable in a boat.
Replace it with a magnetic rod sensor from Wema or Phlippi. |
S&J
Joined: 30 August 2014 Location: Perth WA / Med Status: Offline Points: 1371 |
Quote Reply
Posted: 26 January 2021 at 18:54 |
I found mine used to read 100% until it was about half full and then started to get a little more accurate.
StavrosNZ
Joined: 24 October 2014 Location: New Zealand Status: Offline Points: 581 |
Quote Reply
Posted: 26 January 2021 at 19:49 |
see my post on replacing the factory automotive units with ultrasonic units that have no moving parts in the tank, these are brilliant.
Stephen
Joey D
Quote Reply
Posted: 26 January 2021 at 20:04 |
thank you
Pzucchel
Joined: 13 March 2020 Location: floating Status: Offline Points: 659 |
Quote Reply
Posted: 02 March 2021 at 19:17 |
it seems i have the same problem on a hanse 588...100% reading all the time. It's not the wurth, i swapped the tanks...
However, it is very complicated to access it (port side) and i don't even know the model to order a new one...does anybody know the precise model for a philippi replacement without changing anything else? I had already done the water tank, but i can't find on boatoon the precise reference to the fuel tank sensors for the 588...
Hanse588#55
Goat Island
Joined: 02 September 2019 Status: Offline Points: 5 |
Quote Reply
Posted: 06 May 2022 at 17:35 |
I just purchased a 2019 Hanse 588 and fuel tanks read 100%. What was your fix? Do you have link to parts supplier?
Thanks Johnny
Arcadia
Joined: 27 November 2017 Location: Sag Harbor, USA Status: Offline Points: 1112 |
Quote Reply
Posted: 06 May 2022 at 20:39 |
I have not had this problem yet, but I recall on another post, that the problem is that the float can get stuck in the “full” position when the tanks are filled to the top. I will only fill to 90 percent as a rule. The fix was to remove the sender, push the float down, and put a plastic wire tie on the top to keep it from sticking in the future.
Goat Island
Quote Reply
Posted: 06 May 2022 at 23:09 |
thank you for this information. I will try the fix.
AndyS
Joined: 14 June 2016 Location: River Dunes, NC Status: Offline Points: 206 |
Quote Reply
Posted: 07 May 2022 at 16:33 |
Just as an interesting side note, our fuel gauge on our 385 has always "worked," but shows the inverse of the fuel level. So a 15% reading means that the tank is 85% full. The previous owner said they tried many fixes - including flipping wires, etc - but gave up, so I have always just viewed it as what percentage has been used. And just happy that it kind of worked!
Andy
Moonraker River Dunes, NC |
Post Reply
Page 123> |
| Tweet |
