  New Posts New Posts RSS Feed - dieselindicator not working
peterr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote peterr Quote  Post ReplyReply Direct Link To This Post Topic: dieselindicator not working
    Posted: 18 April 2021 at 10:49
Hello friends.
The lights for the dieseltank and freshwatertank on the control panel has gone out. What can it be.
Best regards peterr
350Bob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 350Bob Quote  Post ReplyReply Direct Link To This Post Posted: 18 April 2021 at 11:36
Hi Peter,
If all the lights have gone out at the same time it may well be the fuse, if you look for the wiring diagram here: https://www.downloadboatmanuals.com/boats/hanse/ and download the first one 320-350 schematic and page down to sheet 5, “DC Main distribution permanent fuses”. You can see there is a 1 amp fuse 9F3 in the supply to the tank battery monitors. I am sorry though I don’t know where the fuse is located, I think most likely it will be in the cupboard under the chart table, but you should be able to find it by following the wiring.
Good luck
Bob
H350 #205
Post Options Post Options   Thanks (0) Thanks(0)   Quote peterr Quote  Post ReplyReply Direct Link To This Post Posted: 18 April 2021 at 12:32
Thank you very much.
best regards peterr
Hanse342 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hanse342 Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2022 at 09:32
Dear Peterr, did you find the fuse panel? I have same problem and couldn't find fuses. Please send photos where it is and what looks like?
Sirri GURLEYUK, a 2006 hanse 342 owner
Post Options Post Options   Thanks (0) Thanks(0)   Quote peterr Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2022 at 10:16
Dear Sirri
It wasn't the fuses, so I didn't find them. it was corrosion on the panel. when you open the panel you will see a print with the electronics for the diesel indicator and batteri. according to my mechanic this print had some corrosion, and it works now. according to the swedish Hanse Forum, the fuses for the panel are located under the table by the main fuse switch.
Kind regards Peter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hanse342 Quote  Post ReplyReply Direct Link To This Post Posted: 13 October 2022 at 10:44
Thank you Peter, i will look under the table. There is a screwed cover. Fuses may be in here. If my problem solved and indicators for battery, water and fuel work, i will inform...
Best regards...
SIRRI
This page was generated in 0.104 seconds.
