Required clearance height for rudder removal |
Post Reply
| Author | |
martijnvdh
Joined: 25 August 2021 Location: Belgium Status: Offline Points: 110 |
Quote Reply
Topic: Required clearance height for rudder removalPosted: 30 May 2023 at 15:32 |
In preparation for next winter's maintenance, and to be able to discuss with the yard:
Does anybody know how much height is required between bottom tip of the rudder and the ground to allow the 371's rudder to be removed? Many thanks!
Mark_J1
Joined: 12 March 2013 Location: Dover&Medway UK Status: Offline Points: 690 |
Quote Reply
Posted: 19 June 2023 at 22:25 |
If it's a similar Jefa steering setup to the 400 (1.98m draft), then FYI with the boat in a cradle adding about 30cm to the overall draft there was plenty of room to drop and remove the rudder. The bottom bearing rotates about the vertical in its 'cup'. So it helps that the rudder can slide out with a small lean backwards limited only by the diameter of the rudder tube.
Mark
martijnvdh
Quote Reply
Posted: 20 June 2023 at 07:39 |
Thanks Mark - yes, I believe the setup to be very similar if not equal to the 400.
Post Reply
| Tweet |
