  New Posts New Posts RSS Feed - Swim Platform Gas Struts
 Post Reply Post Reply Page  123 6>
Newbie Steve View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Newbie Steve Quote  Post ReplyReply Direct Link To This Post Topic: Swim Platform Gas Struts
    Posted: 17 June 2023 at 16:00
Is the gas strut attached to the swim platform actually supposed to do something? It lets the full weight of the platform drop without helpful resistance and does nothing to help raising the platform. Tried turning the whole cylinder but no effect. Also searched manuals, etc. Can you clue me in? (i'm a newish owner). Didn't want to mess with it or try lubricants without experienced advice though did try turning the whole cylinder to no avail. Temporarily rigged 3:1 line pulley system. Thanks,
415 Singapore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 415 Singapore Quote  Post ReplyReply Direct Link To This Post Posted: 18 June 2023 at 02:19
Hi, yes the strut takes the majority of the weight, such that you can close the platform with a gentle pull on the restraining line or open it with a gentle push. It sounds like the gas has escaped from yours. Ours went a few years ago and I got a ridiculous quote of around 350$. I have replaced it with a piece of rope led to the rear winch.
Not as practical but at least I don’t feel like I was robbed!
Good luck
Paul
Paul - Night Train - 415 #136
johanlavenius View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johanlavenius Quote  Post ReplyReply Direct Link To This Post Posted: 18 June 2023 at 13:14
I have the same "problem" and i also talked to two other Hanse 348 owners and they say the same. It's not a "gentle pull on the restraining line or open it with a gentle push".
Maybe we all have faulty struts or its to weak.
Hanse 348 # 93 - Solvind
kipwrite View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kipwrite Quote  Post ReplyReply Direct Link To This Post Posted: 18 June 2023 at 16:09
It's possible to replace these failed original gas struts with aftermarket gas struts, at a fraction of the cost that Hanse charges. In the US, McMaster-Carr has a wide selection.
pdc78 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdc78 Quote  Post ReplyReply Direct Link To This Post Posted: 18 June 2023 at 21:22
All of the aftermarket tension gas struts I have found have been in black nitride finish rather than 316 stainless.  Is that what you purchased?  Has it lasted in a sea water environment?
H345 #269
Post Options Post Options   Thanks (0) Thanks(0)   Quote pdc78 Quote  Post ReplyReply Direct Link To This Post Posted: 18 June 2023 at 21:35
I had two replaced under warranty during the first year.  The top ball bracket was repositioned for the second replacement and then served well for 6 years.  Unfortunately I didn't notice that the top socket fitting was becoming unscrewed from the strut, and the strut detached itself a few weeks ago and went 'plop' into the ocean.  But for some thread lock it would be still providing good service!  ;-))  Word of warning.
H345 #269
Post Options Post Options   Thanks (0) Thanks(0)   Quote kipwrite Quote  Post ReplyReply Direct Link To This Post Posted: 19 June 2023 at 01:53
Yes the black strut seems to be good so far. Has outlasted the stainless one supplied by the factory.
boatman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boatman Quote  Post ReplyReply Direct Link To This Post Posted: 20 June 2023 at 00:10
Brand new 348. Terrible design. Struts do nothing to help you pull up the platform. You need to be a weightlifter to get it back closed with just the line. No way my wife could even attempt this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 415 Singapore Quote  Post ReplyReply Direct Link To This Post Posted: 20 June 2023 at 04:52
Hi, very strange they got it so wrong on the 345 and 348. On the 415 I would estimate that the strut took 95% of the weight.
All the best
Paul
foxdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote foxdog Quote  Post ReplyReply Direct Link To This Post Posted: 20 June 2023 at 07:45
I use laser dinghy main sheet rig with swivel and cam lock. Works great. My piston crapped out after one year.
348 Hull#174 2021
This page was generated in 0.447 seconds.
