  New Posts New Posts RSS Feed - Bow fitting for gennaker and code-0
johawa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johawa Quote  Post ReplyReply Direct Link To This Post Topic: Bow fitting for gennaker and code-0
    Posted: 12 December 2023 at 08:36
Hey.
My Hanse 411 from 2001 has no strong bow fitting, that is originally made for gennaker or code-0 sailing. The stainless steel front plate at the steven works as fixing plate for the forestay. This is not connected to the top plate at the bow, where the bow pulpit is mounted on.
Do you have a solution for this? Can you show your bow arrangement?
BR
Johannes
Hanse 411 - AAVA
martijnvdh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote martijnvdh Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2023 at 09:03
The 411 and 371 are more or less of the same design - my 2005 built 371 has a separate "pipe" piece that should be inserted on the bow, to attach a gennaker. The clew is too close to the forestay for a code-0 on a furler (or so I have been told).
I only have a gennaker, so works fine for me.
The pin can be found here, or on the Hanse Boatoon site:
Genaker Pin für Bugbeschlag - NIRO Petersen (niro-petersen.de)
Post Options Post Options   Thanks (0) Thanks(0)   Quote johawa Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2023 at 09:41
Hey. Thanks for your very quick response.
We do not have this solution. Here is a picture from our bow construction. They tried to use a stainless steel ring, mounted on the anchor fitting, to attach the tack line of the genanker there. Unfortunately ... the anchor fitting is only connected to the stainless steel top plate. And this is only fixed by one screw at the front part to the boat hull. The loads from the gennaker (to the sides and upwards) can not handled by this... The top plate moves some mm up by using a Gennaker there. Thats why we are looking for a better solution. The loads have to be directed more downwards.
Hanse 411 - AAVA
PekkaL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PekkaL Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2023 at 14:51
I have a 371 with 60m2 code0, which I use in light to moderate wind to ≈40° apparent.
This requires quite tight sheeting: I have double  halyard up to mast and occasionally use also an inhauler  to keep the sail in shape.
I have often  sheeted this as tight as I can with the regular 40x Harken winch & double halyard ... yes, in 10 years the "pipe" is like new, but there is light bend on the tube it attaches to.
Works well for me (know on wood).
Edited by PekkaL - 12 December 2023 at 14:52
Pekka Leppanen, "Vedette"
Post Options Post Options   Thanks (1) Thanks(1)   Quote PekkaL Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2023 at 14:57
This is the other side of my arrangement: the double halyard. You'll note that tight sheeted codes like to eat halyards - unlike spinnakers or gennakers. You really need to go through the block and not the metal eyelet in the mast.
dd
Edited by PekkaL - 13 December 2023 at 08:28
Dogscout View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Dogscout Quote  Post ReplyReply Direct Link To This Post Posted: 12 December 2023 at 22:33
I will gladly add to that. Adding the block will save the halyard. I ran mine through the eyelet and the chafe of an Atlantic crossing cut through the sheath.
Adventure awaits
Post Options Post Options   Thanks (0) Thanks(0)   Quote johawa Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2023 at 10:47
Dear PekkaL,
do you have a wider photo of this section? I would like to see the bow fitting arrangement below the anchor roll.
BR
Johannes
Hanse 411 - AAVA
Post Options Post Options   Thanks (0) Thanks(0)   Quote PekkaL Quote  Post ReplyReply Direct Link To This Post Posted: 21 December 2023 at 18:22
You can barely  see the bow: there is nothing supporting the gennaker/code0 attachment. There is a support for the teak step, though.
This page was generated in 0.064 seconds.
