  New Posts New Posts RSS Feed - Fuel tank inspection hatch
stownsend View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stownsend Quote  Post ReplyReply Direct Link To This Post Topic: Fuel tank inspection hatch
    Posted: 13 May 2024 at 08:57
Hi All
Sorry, me again and quick question, I’ve looked under the rear berth at the fuel tank and the fuel tank inspection hatch is between the two openings so not easy to get to, can the tank be move over to gain access to the hatch?
I’d like to fit a gauge sender and the easiest option is to fit it in the inspection hatch as it can be removed and drilled away from the tank.
Stu
Post Options Post Options   Thanks (0) Thanks(0)   Quote stownsend Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2024 at 20:14
Hi all
Just for an update, spent some time crawling around the aft cabin this afternoon and found 3 bolts holding the tank up so by the looks, release them and the tank can move to mid opening and the hatch can be opened up.. that’s the theory anyway!
Stu
Bitbaltic View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bitbaltic Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2024 at 22:14
Be interested to hear a report of you do it Stu. Often wonder what the inside looks like after 23 years since build!
sailingfree View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sailingfree Quote  Post ReplyReply Direct Link To This Post Posted: 11 June 2024 at 22:29
Hi Stu,
Yes the tank can be moved around after the bolts have been loosened, but sadly it cannot be completely removed. Mine had an after market gauge fitted which is accessible from the opening in the aft cabin floor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stownsend Quote  Post ReplyReply Direct Link To This Post Posted: 25 June 2024 at 22:05
Thanks for the info, I’m trying to find a spare few hours to get dien there!
Stu
Post Options Post Options   Thanks (0) Thanks(0)   Quote stownsend Quote  Post ReplyReply Direct Link To This Post Posted: 09 September 2024 at 21:44
Hi All
Finally got down to the boat today and managed to install the sender. To say the least, it was a blighter to fit. One thing to watch out for was the rubber seal. It appeared to be across the whole of the hatch but had disintegrated so some was resting in the tank.
The black marks in the tank on the video weren’t moving when I shook and moved the tank, don’t think it’s the bug.
Here’s the link to the video of the fuel …  https://youtube.com/shorts/noeGGALAn54?si=5egjLSETxcQkAi6P
Once I workout how to upload the photos I’ll add a couple in!
Stu
Edited by stownsend - 09 September 2024 at 21:45
Martin&Rene View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Martin&Rene Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2024 at 17:31
Stu
Use the post reply button at the bottom of the thread, rather than the message box.  An image button then comes up so you can upload an image (I tend to do around 400-600 pixel dimensions) on to the site and then you place it at the position you want.
This page was generated in 0.247 seconds.
