  New Posts New Posts RSS Feed - 505: Water Tight Bulkheads
SVZara View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SVZara Quote  Post ReplyReply Direct Link To This Post Topic: 505: Water Tight Bulkheads
    Posted: 12 July 2024 at 04:45
Is the forepeak/sail locker a water tight bulkhead?   What about the aft lazarette?  If they are not water tight, has anyone tried to make them water tight?  I saw a boat sink when they cracked their rudder post and I would really not have to worry about this happening if something went wrong with the rudder.  Thoughts?
Marc
S/V Zara
2016 Hanse 505, Hull #129
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arcadia Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2024 at 06:50
On my 588, the forward and aft both are water tight with glands where pipes and cable pass through. Two things though, the aft bulkhead has an opening above the water line for steering drag links to pass so not a big safety margin there. Also underway or healed over it will probably pass water. But more to the point, my rudder shaft enters the hull FORWARD of that bulkhead between the aft cabins. It’s inside its own compartment, but not water tight! I’m aware of the sinking yacht episode and I’m  in the process of devising a solution. BTW for any 575 owners, the same is true.
perry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote perry Quote  Post ReplyReply Direct Link To This Post Posted: 12 July 2024 at 07:44
Hi, I have been aware of the lack of  waterproof bulhead design on modern yachts, and recent sinking with rudder shaft fails etc. And historically the Titanic less than waterproof bulkheads?
Recently I viewed a "Sailing Uma" video you may like to watch:-
Perry
Cowes UK
 Yacht Bloto-4 H315
Current Yacht Hanse 315 2007
Post Options Post Options   Thanks (0) Thanks(0)   Quote SVZara Quote  Post ReplyReply Direct Link To This Post Posted: 14 July 2024 at 04:28
On the 505 our rudder post is within the aft lazarette which seems to be water tight.  We have the glands too but I am not sure I am 100% convinced it is water tight.  I wish there was a way to really test this without sinking the boat.  Does Hanse claim these are watertight?  I have to assume they tested this themselves as part of their certification process, or am I being naïve.
Are glands really water tight or is it just "resistant"?
Edited by SVZara - 14 July 2024 at 04:29
Marc
S/V Zara
kipwrite View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kipwrite Quote  Post ReplyReply Direct Link To This Post Posted: 14 July 2024 at 12:23
The aft lazarette on my 505 is not water tight. There are openings down low, where things like the engine fan exhaust, engine controls, wet exhaust, and genset wiring pass through the bulkhead, and these are not fully sealed. I recently installed a new genset and a starlink - so I'm familiar with these opening. I believe the autopilot wiring is up at deck level and sealed - not that the sealing would make any difference.
Far as I can tell the forward bulkhead is watertight, though there is a wire run, starboard side, up near the deck, so if flooded (god forbid) it might flood the forward stateroom and main cabin. I added a bilge pump to the forward lazarette, which I think is a mandatory add to our boats.
Curious if your aft bulkhead is indeed water tight. Might want to check down low.
Edited by kipwrite - 14 July 2024 at 12:29
Post Options Post Options   Thanks (0) Thanks(0)   Quote SVZara Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2024 at 20:48
Do you think changes could be made to make it mostly watertight?  At least below deck level.
Marc
S/V Zara
Post Options Post Options   Thanks (0) Thanks(0)   Quote kipwrite Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2024 at 21:59
Be very difficult to make all this watertight. Have a look and let us know what you think.
Edited by kipwrite - 18 July 2024 at 22:01
Post Options Post Options   Thanks (0) Thanks(0)   Quote SVZara Quote  Post ReplyReply Direct Link To This Post Posted: 29 July 2024 at 22:34
Yup.  I crawled all around the lazarette today.  It seems the center channel is the only opening leading to the bilge.  I didn't see anything on the sides at all.  Its really too bad that channel wasn't run just under the deck.  That would at least give some leeway and time before the aft bulkhead would have been breeched.  Relocating them would be tricky.  The only other option I can think of would be to fill the area with expanding foam to at least slow any egress.  Time is of the essence in these situations.  Maybe put in some glands, and glass the hole closed.
The rudder tube that the post is in seems VERY strong but what do I know.  Very thick solid fiberglass.  If the rudder post was sheered, could that tube withstand the lose end churning around against the sides?
All these sinking's from the Orcas taking out the rudder post has kinda freaked me out.  While me sailing to the Med some day is part of my long term dream, its not within the next five years.
Marc
S/V Zara
jdderijke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jdderijke Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2024 at 09:03
I tested the rudderpost and the tube you mentioned. I hired a group of 6 orca's and they had some some fun with it. Rudder was severely damaged, part of the internal (in the rudder) aluminum reinforcement was even sheered of and the top bearing was damaged, steering cables snapped etc.... but..... rudderpost was not bend, bottom bearing survived and the tube was fine... No water ingress whatsoever.
Having said that.. i would definitely like a watertight bulkhead in the aft lazarette.
(on a side note: Who came up with the idea to design the emergency steering for reversed use... you basically have to lower the bathing platform and stand on it to use the emergency steering. And this is not something you want to do with orca's swimming around the boat or in heavy weather)
JD
Post Options Post Options   Thanks (0) Thanks(0)   Quote SVZara Quote  Post ReplyReply Direct Link To This Post Posted: 21 September 2024 at 16:53
Wow.  I am so glad to hear you guys survived the attack.  I do feel a little better to know that the boat survived and the rudder tube was strong enough.
Marc
S/V Zara
This page was generated in 0.398 seconds.
