Forum Home Forum Home > Hints & Tips > 460
  New Posts New Posts RSS Feed - Water and Fuel Tank calibration
mr-ludi View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote mr-ludi Quote  Post ReplyReply Direct Link To This Post Topic: Water and Fuel Tank calibration
    Posted: 17 July 2024 at 12:08
I have measured some calibration points of the two tanks.
Maybe some other users can add more datas, especially of the fuel tank?!
Water:
Sensor: SH220 [0412] 1
Capacity: 450 Liter
0-209L: 3-4 Ohm (it can‘t measure <210L)
210L: 17 Ohm
250L: 44 Ohm
300L: 71 Ohm
350L: 112 Ohm
400L: 159 Ohm
425L: 178 Ohm (maximum, it can‘t measure >425L)
Fuel:
Sensor: SH220 [0412] 3
Capacity: 200 Liter
115L: 151 Ohm
The datas of the water tank shows, that the sensor is able to measure from 210-425L. It‘s a range of 215L (47,8%) from a 450L tank. Bad, what Hanse is selling at this point…
Edited by mr-ludi - 17 July 2024 at 12:11
Keakaka View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keakaka Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2024 at 00:36
We have the same problem on our 460 for over a year. Our agent is talking to Hanse about a fix but they think it is not possible for the water as the tank is on a slope and not even size. We show 30% water when there is actually 70%. This is a major problem when we have others on board as we have no idea about water levels. We are going to try a different sensor maybe using pressure not probes or else a sight tube so we can see the level.
https://wema.co.uk/products/fuel-sender
https://wema.co.uk/products/nmea2000-n3-sender
Fuel is not a problem as we work off engine hours at 5 litres per hour average.
Very disappointing responses from Hanse on this and the anchor chain buildup problems.
This is not a rehearsal. Go for it. Kiakaha
Post Options Post Options   Thanks (0) Thanks(0)   Quote mr-ludi Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2024 at 07:14
I don’t have that problem.
Our sensor/tank combination works well between 215L and 425L (48% to 94%). But if we have less than 215L, the sensor can‘t measure it any more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote S&J Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2024 at 21:20
It sounds like the sensor is too short.  They come in different lengths.  From memory my 458 with a 450l tank has either 30 or 35cm sensor.
The original supplied by Hanse failed in my 3rd season however the €40(?) drop in replacement has proved much more accurate.
The original showed 100% until about 60% usage when it started measuring correctly (but obviously based on just the 69% volume.)
Edited by S&J - 20 July 2024 at 16:02
ariette View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote ariette Quote  Post ReplyReply Direct Link To This Post Posted: 19 July 2024 at 07:09
Ludi
On the fuel tank I can add
210 litres 191 ohm
140 litres 171 ohm
Thanks for your water numbers
Post Options Post Options   Thanks (0) Thanks(0)   Quote mr-ludi Quote  Post ReplyReply Direct Link To This Post Posted: 19 July 2024 at 08:23
Originally posted by ariette ariette wrote:
Ludi
210 litres 191 ohm
140 litres 171 ohm
I measured my fuel data by checking the ohm number before refueling and counting the liters from full tank.
Did you do the same?
My display was configured by 210L capacity.
But all specifications for the H460 are showing a fuel capacity of 200L.
What is correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ariette Quote  Post ReplyReply Direct Link To This Post Posted: 19 July 2024 at 10:42
Yes I did the same. I don't know which is correct. The documentation mentions both 200 and 210 litres and my dealer doesn't know the answer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mr-ludi Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2024 at 11:24
If we trust in the documentation, it‘s a 200L tank. This would meand we have
151 ohm @ 115L
171 ohm @ 130L
For me it looks time the sensor will reach the maximum of 191 ohm much earlier than @ 200L… 🙄
I will try to refill as slow as possible next time and get more datas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote S&J Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2024 at 16:01
458 has a 210l diesel tank.  Maybe some documents didn't get corrected for 460?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mr-ludi Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2024 at 16:25
I think it‘s the opposite.
I haven‘t seen any document showing 210L for the 460.
The only reason to think about 210L is the display, which shows a maximum volume of 210L.
Maybe the display is copied from the 458?!
This page was generated in 0.184 seconds.
