  New Posts New Posts RSS Feed - Volvo penta check engine message
Pzucchel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pzucchel Quote  Post ReplyReply Direct Link To This Post Topic: Volvo penta check engine message
    Posted: 16 August 2021 at 10:34
Hello, going to corse I had the message " important : check engine / verify ops manual". No further information. Do you know what's about? There is no further information...thank you guys!
Edited by Pzucchel - 16 August 2021 at 16:25
Hanse588#55
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayne's World Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2021 at 15:04
Pzucchel,
If you check the Volvo engine start/stop panel at your helm station and scroll through the options until you get to the screen that will say "1 Fault". It is possible to enter on this screen and get the engine error code. You can then Google this engine error code and hopefully find the description of the fault which will be in a format like MID 128 PSID 96 FM 1. The MID 128 generally refers to the fuel system and in this case the complete error code specifically refers to a (common) rail system low pressure. Most of these MID 128 problems stem from lack of fuel supply or low pressure/volume of fuel supply. The cause is generally clogged fuel filters or fuel lines. I will email you the only VP EVC error code listing I have been able to find which is in French but sa la vie!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pzucchel Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2021 at 16:24
Fantastic! This is the error code from the volvo app:
MID: 128  PID: 164  FMI: 1
Could you please send me the message list?
Thank you....
Piero
Hanse588#55
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayne's World Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2021 at 16:35
Piero,
I have sent you a private message via the forum which should have the PDF of the error code list attached. I'm not sure the PDF will get to you via the PM option. If it doesn't get to you PM me your email address and I will send it to you that way.
The Error Code you have refers to   "Pression de commande d'injection" or INJECTION CONTROL PRESSURE. This could be associated with partly blocked filters or partly blocked fuel lines. If you can't find the problem and fix the error you probably need a a good Volvo technician.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pzucchel Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2021 at 16:38
Well received! Thank you Wayne for your usual courtesy...
Hanse588#55
Berghezan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Berghezan Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2023 at 09:28
Can you please send me the pdf with the errore list of volvo penta.
I have a starfisher boat with two volvo penta engines d3-190 and I have an error code: MID 128 SID 27 FMI 1. TORQUE REDUCED.
THANKS.!
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayne's World Quote  Post ReplyReply Direct Link To This Post Posted: 07 October 2023 at 14:28
Berghezan,
The fault code appears to refer to a problem with the turbo.
I have sent the code list to you via this sites private message system. Sorry it is in French.
marcopone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote marcopone Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2024 at 07:48
hallo,
I got this error popping up on my D3 :
MID 128  PSID 129  FMI 4
I can not find the meaning, someone can help me ?
many thanks, Marco
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayne's World Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2024 at 08:44
Marco,
This fault code appears to refer to an alternator fault.
Post Options Post Options   Thanks (0) Thanks(0)   Quote marcopone Quote  Post ReplyReply Direct Link To This Post Posted: 14 August 2024 at 09:51
thank you Wayne
as a matter of fact the alternator fault is exactly what I am experiencing.
it is not charging the batteries, even not the sole engine battery
very bad
bye, Marco
This page was generated in 0.162 seconds.
