  New Posts New Posts RSS Feed - Panda raw water pump leak
kipwrite View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kipwrite Quote  Post ReplyReply Direct Link To This Post Topic: Panda raw water pump leak
    Posted: 12 April 2018 at 19:56
Went to change the oil on my Panda 10000i genset today (160 hours) and discovered dried salt all over the front of the unit. I think the likely culprit is the sea water pump seal, based on the rust by the weep hole where it mounts to the block. I’ve ordered a new pump and will rebuild the old one as a spare.
Otherwise this genset works as it should.
Anyone ever remove and replace the sea water pump on one of these Kubota engines? Can’t find documentation of how to do this.
Note, Fischer Panda advised replacing this pump as soon as possible. A catastrophic sea water leak from the sea water pump quickly fries the electronics on these gensets, apparently. This is a known fault with these Johnson F4B-9 pumps, according to the US distributor in FL. 160 hours/2 years is a pretty short life span. Sheesh.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayne's World Quote  Post ReplyReply Direct Link To This Post Posted: 13 April 2018 at 10:18
Kipwrite,
We have a FP 10Kva unit onboard and have had the same problem. The pump is crap. We now have 930 hrs after our 4 year of liveaboard and purchased a a new pump, rebuilt the original pump and then both had the same issue again. I have just had both pumps rebuilt over winter.
To remove the pump -Remove the water hoses after turning the water vales off, then there is a bolt (about 7mm - 1/4in head size and about 50mm - 2 inches long) which goes through the clamping arrangement which holds the pump on the motor. Once you remove this bolt you will be able to pull the pump out of the motor housing. You don't need to remove any other bolts, just this one.You may need to use a flat screw driver to pry the pump out and maybe a back and forth twisting action will help. But it will come out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kipwrite Quote  Post ReplyReply Direct Link To This Post Posted: 13 April 2018 at 17:55
Thanks. This is really helpful.
marcopone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote marcopone Quote  Post ReplyReply Direct Link To This Post Posted: 22 August 2024 at 09:53
same problem on my FP 8000i
a lot of problem with this crap pump
to service it is a nightmare, very poor accessibility on my H575
very often I get broken impellers !
the right solution would be to have an external electric pump placed near the AC sea water pump
also a bigger sea water filter, the original one is often easily clogged and this destroy the impeller
I would leave the other filter after the pump to collect the broken impeller blades.
unfortunately no information are available from FP about which pump size to use and how to connect it to the gen set so that it will switch on/off automatically.
any help would be much appreciated !
br, Marco
This page was generated in 0.064 seconds.
