  New Posts New Posts RSS Feed - How not to lose end stop
dobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dobrien Quote  Post ReplyReply Direct Link To This Post Topic: How not to lose end stop
    Posted: 03 September 2024 at 13:27
I recently lost my self-tacking jib traveler end stop and have just replaced it. Has anyone worked out a way to stop the traveler before it hits the end stop? Can the jib car be tied somehow to limit its travel using dyneema for example?
Post Options Post Options   Thanks (0) Thanks(0)   Quote S&J Quote  Post ReplyReply Direct Link To This Post Posted: 03 September 2024 at 20:14
What size boat is this?  Neither my 385 or 458 have issues with the end stop.  It is bolted into an alloy plate in the deck with two large bolts which are quite stubborn to remove.  The stopper seems to have adequate cushioning to cope with the forces generated in tracking.
perry View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote perry Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2024 at 19:00
Updated 5/9/24 with photos of Self tacker arrester cord
I have a length of paracord about 3-4 mm dia  tied to a fitting on mast and tied off to the traveller, its set so it arrests the traveller roughly 5-6mm  before the traveller hits the stop. I takes the shock out. Used with success on my H301 and H315.
 I will take photo to clarify tomorrow and update this post.
Perry
H315 [2007]
I have struggled with photo format but hope you can see its just simple cord to arrest the self tacking car just before impact with end. In a good breeze hard tack the car may hit the end stop but having lost significant endergy to the cord.
Edited by perry - 05 September 2024 at 16:16
Current Yacht Hanse 315 2007
Post Options Post Options   Thanks (0) Thanks(0)   Quote dobrien Quote  Post ReplyReply Direct Link To This Post Posted: 04 September 2024 at 22:46
Thanks Perry, I would love to see what you have done, thanks Dallas
Post Options Post Options   Thanks (0) Thanks(0)   Quote dobrien Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2024 at 21:29
My boat is a 418. I also had this issue with a 2012 H385. The M6 set screws used to hold the end stops are undersized, hence their repeated failure. In a 30 knot squall the screws just sheared off. With much effort I have replaced the screws with M8
Post Options Post Options   Thanks (0) Thanks(0)   Quote dobrien Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2024 at 21:41
Thanks for sharing
Post Options Post Options   Thanks (0) Thanks(0)   Quote dobrien Quote  Post ReplyReply Direct Link To This Post Posted: 15 September 2024 at 01:43
hi,
I have had it happen twice now on 2 Hanse boats. First was a 2012 H385, and more recently a 2021 H418.  On both occasions my rigger has changed the M6 bolts for M8's.  Those accidents happened in a 30kt squall off the Sydney coast.  The M6 screws just sheared off.
TouchOfGrey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TouchOfGrey Quote  Post ReplyReply Direct Link To This Post Posted: 05 January 2025 at 13:40
Hi Dobrien,
We had same issue on our H418 #28. After loosing one end stopper in 2022, we had both stoppers (original Selden type 443-142-010 replaced by a Heavy Duty stopper from Selden, type nr 443-166-01
No issues since...
Henk
Touch of Grey
Henk
Touch of Grey
H418 #028
Miraculix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Miraculix Quote  Post ReplyReply Direct Link To This Post Posted: 21 January 2025 at 23:41
We had a similar problem: the end stopper broke and we found one part lying on deck (see photo). The screws were still in place. Going for stronger screws would not have prevented this damage - in contrary, bigger holes would have weakened the end stopper further more. I‘ll follow Henks advice - thanks for that.
Miraculix - Hanse 418-182
This page was generated in 0.142 seconds.
