  New Posts New Posts RSS Feed - Cruisair air conditioning pump
Post Options Post Options   Thanks (0) Thanks(0)   Quote Black Diamond Quote  Post ReplyReply Direct Link To This Post Topic: Cruisair air conditioning pump
    Posted: 09 May 2025 at 21:37
Can someone explain to me the proper behavior of the air conditioning circulation pump?   On my 575 its installed under the sole near the companionway.   I have a manifold setup that has slightly changed from the delivery as I replaced all the seacocks and the strainer.  The support layout for AC is the same with the 3 salon and aft air conditioner feeds/returns while the forward AC units are served forward.   I also insulated the floor and removable access hatch which reduced the originally intolerable pump noise by 90%.
The problem is that the pump never seems to shut off when using it for AC or reverse heat.  When the breakers are flipped it goes on.   When the AC units have either heat or cold temps at the thermostat set levels, it still seems to be on.
Is this normal?   You would think that if none of the AC unit compressors was running that it would not need the circulation pump running.    If the compressor kicks in, then it seems logical to signal the pump to start up.   Not happening.
 I've had the boat for 7 years and never really noticed this since we don't use the AC except for early season heat and the hottest of summer days.
32mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 32mike Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2025 at 00:10
Rick,
I have a 458 with three factory supplied A/C units installed. There is also, what sounds like a similar pump/manifold setup with one Dometic circulation pump under the floor. My pump does not run continuously - it on,y comes on when signal,Ed to by one of the AC units. It can seem like it’s running continuously during the hot days down here but when things cool down at night the AC’s and the pump will shut down.
Maybe one of the control boxes wiring is wrong? Or perhaps a setting on one of the thermostats? Don’t know how far you’ve delved into those settings but there’s a lot of them that can be changed. In either case maybe you can troubleshoot by trying one unit at a time to see if one of them is triggering the pump when you flip its breaker. Does the pump go on if you only turn that breaker on and no AC’s?
S/V Dulces Sueños
458 #087
Tampa, FL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayne's World Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2025 at 03:48
Rick,
Sounds like our air cond system is the same as your - which makes sense. I am fairly sure our cooling feed pump runs continuously only the individual air cond compressor units stop and start as they reach the set point temp. I guess all four air cond compressors would need to stop at the same time for the feed pump to shut down if the system was set up like that. If one air cond unit is still running that unit still needs cooling water. The feed pump obviously supplies all air cond compressor units. I guess you could test the system but just running one air cond compressor and close that area (cabin) off so the unit would reach the set temp and shut down. If the feed pump still runs I guess the answer is no the feed pump runs continuously when any or all air cond compressors are on. Good idea to sound insulate the area where the feed pump is.
Gale Force View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gale Force Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2025 at 08:03
My pump works as per Wayne's description.It only stops running when you power off all units from their individual control panels.
Duncan
Wild View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wild Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2025 at 10:11
We haven’t the factory AC installation.
We did it by ourselves and fit a pump relaybox ,2 to 6 units can connected,from Climax marine easily to Google.
When one of compressors starts up ,and only the compressor not the units himself, the AC waterpump starts automatically and stop when none is running.
Belgium
545e#268
Wild View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wild Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2025 at 10:49
Sorry the brand of the pump relay box = Micro-air well now in USA.
Belgium
545e#268
Pzucchel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pzucchel Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2025 at 11:46
i have a frigomar setup: it has bldc motors that help reducing the energy consumption by modulating the power/rotation speed instead of on/off switching). In my case, the central water pump does shutdown when none of the units is drawing current. It has a slight inertia, about 30s-1m delay from the start of any of the 4x heat exchangers, noticeable also when you switch on the system.
I am very happy with it: only defect is that the water pump sometimes doesn't self prime after sailing/heeling, and it resulted in a burnt water pump before i learnt to check the priming after navigation...It is more an installation issue than an issue of the aircon itself. I can also use it on batteries with some caution (one heat-exchanger only, and not to the maximum power)...
...just for the record...
Hanse588#55
Post Options Post Options   Thanks (0) Thanks(0)   Quote Black Diamond Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2025 at 14:20
Thanks for all the inputs...   I'll be running some tests when I get to the boat again and will post my findings.     I have 4 AC breakers.   One for the circulation pump and 3 that control the 1 forward, 1 aft, and 2 salon AC units.   I assume this is a standard 575 setup.   I will be checking:
1.  When I flip the circulation pump breaker, but not the others, does the pump run?
2.  If not,  then does flipping just one of the other breakers cause it to come on?
3.  If so, which one?
4.  If the answer to (1) is yes,  then I guess I need to check what the pump wiring / signals are supposed to do.  Maybe (to the point raised) there is a setting that tells it to shut off if the other AC units are not on.    I'll have to find the pump manual and the manual for the AC units to do this.
Edited by Black Diamond - 10 May 2025 at 14:28
Post Options Post Options   Thanks (0) Thanks(0)   Quote 32mike Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2025 at 15:21
Rick,
That’s the same breaker arrangement that I have. If the boat is relatively cool, I.e., all temps are below the thermostat settings, when I turn on all of the breakers, nothing happens with the pump. It will only turn on when a thermostat signals an AC unit to turn on. When that happens, the pump turns on first for a few seconds before the AC compressor starts. The opposite happens when a compressor shuts down - the pump will continue to run for about 5 seconds before it shuts down. It stays off until a thermostat triggers it on.
Good luck.
S/V Dulces Sueños
458 #087
Tampa, FL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arcadia Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2025 at 21:58
Rick. The standard Hanse installation includes a 1 x 4 relay unit which is wired between the pump breaker and the pump. It will only pass voltage to the pump when it detects at least one compressor is operating. Otherwise the pump will be switched off. These units can fail. Mine did and it can go always on or always off. I guess always on is better but it’s still a malfunction.
This page was generated in 0.117 seconds.
