  New Posts New Posts RSS Feed - Battery location
Battery location
PabloPicasso View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PabloPicasso Quote  Post ReplyReply Direct Link To This Post Topic: Battery location
    Posted: 15 May 2025 at 20:55
My 301 has 2 batteries on the port side under the aft double bunk.
There is nothing to tie them down to, and the auxillary(domestic) battery is too big to fit in the space.
The central locker houses the exhaustn
 muffler, so no space there. The starboard locker has the fuel tank. Again no space for a battery.
Perhaps a battery box in the corner of the aft berth next to the engine cowling could be fitted?
I'm open to ideas!!
Mergus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mergus Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2025 at 19:07
Hi, I used to have the same problem, although I had on port side the engine battery+aux battery, and then on stb side another aux battery in front of the fuel tank, so close to the kitchen wall. They were both 75AH lead-acid batteries that barely fitted the space (managed to find some Varta battery that fitted). This year replaced both aux batteries with LiFePo4 batteries (https://uk.litime.com/products/litime-12v-50ah-lifepo4-lithium-ion-battery) that fit easily, and have the same usable capacity as a 75 Ah lead-acid. Works perfectly.
EDIT: These were the old ones I had that barely fitted (https://www.hankkija.fi/tarvikkeet-ja-huolto/akut/ia-akku-12v-74ah-750a-silver-dynamic-e38-varta-2045391/). And naturally I still have one as starter battery
Edited by Mergus - 20 May 2025 at 19:26
stownsend View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stownsend Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2025 at 10:42
Hi All
This is the battery I used to replace the domestic one, 12V 110AH 110 AH SB HL400 Leisure Battery DEEP CYCLE Motorhome Caravan Campervan - ebay link, showing out of stock but available at loads of places .. 12V 110AH 110 AH SB HL400 Leisure Battery DEEP CYCLE Motorhome Caravan Campervan | eBay UK
It was a low level one and fitted like a dream under the aft cabin berth, needed to move one of the wooden brackets I've got fitted to mine.  The +ve and -ve terminals are in the correct for wiring on my setup.
Hope that helps.
Stu
Post Options Post Options   Thanks (0) Thanks(0)   Quote PabloPicasso Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2025 at 11:03
Thanks for that
Ill let ypu know how i get on
sailingfree View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sailingfree Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2025 at 15:44
Yes I found that having the domestic battery in the aft hatch a real pain, and when I got a slightly bigger battery it of course did not fit. I eneded up strapping it down next to the sink. This is what mine looks like. The webbing has been screwed to the bulkhead.
This is awfully tatty and I have always meant to get around to putting a box over it, one day perhaps.
Pete
