Forum Home Forum Home > Hints & Tips > 460
  New Posts New Posts RSS Feed - Bathing Platform Stuck
rodolfobm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rodolfobm Quote  Post ReplyReply Direct Link To This Post Topic: Bathing Platform Stuck
    Posted: 26 June 2025 at 17:32
Hey guys!
We just got our 460 a few weeks ago and, after just 2 or 3 uses, the electric bathing platform is stuck on the up position (thank God).
When I try to lower it, the rope actually pull it in tighter. I think it got tangled somehow inside the motor.
Has anyone had this issue? Any ideas are more than welcome!
Thank you!
R. Martins
mr-ludi View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote mr-ludi Quote  Post ReplyReply Direct Link To This Post Posted: 26 June 2025 at 20:03
Yes, I had the same issue.
But it wasn‘t hard to solve.
The rope flipped over at the motor. You have to lift the platform by hand and sort the rope carefully.
To avoid that it in the future, you have to stop immediately when the platform reaches the lowest point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rodolfobm Quote  Post ReplyReply Direct Link To This Post Posted: 29 June 2025 at 04:42
Hey Mr. Ludi!
Thank you for the tip, but my issue was on the battery!
We actually unplugged and replugged inverted the battery connection to the motor (you can find a Quick Brand battery connection under the helm, in the locker).
Well, not me, but the technician that came over inverted the cables on that thing and now everything work perfectly (which is mind boggling). Go figure!
R. Martins
ariette View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote ariette Quote  Post ReplyReply Direct Link To This Post Posted: 20 October 2025 at 17:17
Mine did the same and was locked in the up position. I had to cut the dyneema to free it and realised that the Hanse turning block (cheap rubbish) was not turning and the dyneema had almost burnt itself to nothing as it made its way across the seized block. I replaced the dyneema with Vectran so there is a cover to protect it and replaced the dodgy block with a Harken block I had on board. Might be worth checking yours.
Also, my Quick motor is really noisy- is that everyone's experience?
Edited by ariette - 20 October 2025 at 17:18
This page was generated in 0.115 seconds.
