  New Posts New Posts RSS Feed - Replacement Service Battery AGM 12V/160Ah?
Protea View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Protea Quote  Post ReplyReply Direct Link To This Post Topic: Replacement Service Battery AGM 12V/160Ah?
    Posted: 04 October 2025 at 20:55
I need to replace my two Service batteries (AGM 2V/160ah). My broker and Boathoom list the Longex AGM 2V/160ah battery as being compatible for Hanse 418s and my boat, a Dehler38. However both of these boats need two batteries with flat terminal heads that protrude far enough for a battery bridge (clamp) to attach them together. I cannot find any AGM 2V/160ah batteries with “flat” not rounded terminals with holes in them to install in these sailboats. Ordering batteries from Germany is also very expensive. West Marine has an AGM 2V/160ah battery but it does not have the flat terminal heads either. What are people using in the US?
Lyn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lyn Quote  Post ReplyReply Direct Link To This Post Posted: 04 October 2025 at 22:19
When my AGM 165Ah (x2) bow thruster bank went out, I had similar difficulty.  I did go the West Marine route with this one.  For clarity, the default picture shows tabs.  I didn't get any.  Instead, I had just bolts which you'll see if you click on one of the terminal zoom-ins.  Those bolts back all the way out.
I then bought some copper flat bar.  Couldn't find any locally at a variety of electrical supply shops -- thought they would have stock bus bar.  Anyway, a company like onlinemetals, speedy metals, etc.  I went with 1/4" thick and about an inch wide.  Then cut to length, bent a 90 degree, and then drilled holes.  Short end to mount to the battery.  I think I had to do a few different holes on the longer standing end to accommodate a variety of things hanging off (e.g., voltage monitor, charger and loads etc.).  Maybe something like this could work for you.
Edited by Lyn - 04 October 2025 at 22:22
Jon
S/V Lyn
2017 Hanse 588 | Hull 19 | Deep draft | 150hp | 220v & 110v systems | Lithium House Bank
32mike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 32mike Quote  Post ReplyReply Direct Link To This Post Posted: 05 October 2025 at 00:45
Try looking at Victron AGM’s. I swapped out my factory Q batteries for the Victron 165ah AGM’s and it was an exact fit with the same terminals for the factory joining bars. Didn’t have to modify anything. I bought them from a local supply house that just had them shipped from the Victron warehouse wherever that was - Peterson Marine IIRC, but they were listed at other shops as well online.
S/V Dulces Sueños
458 #087
Tampa, FL
This page was generated in 0.183 seconds.
