Rain water infiltration |
Post Reply
| Author | |
Davide
Joined: 28 October 2018 Location: Italy Status: Offline Points: 16 |
Quote Reply
Topic: Rain water infiltrationPosted: 05 October 2025 at 10:32 |
Good morning to everyone!
I find water (rain water) under the floor of rear cabins, mainly the left one, it accumulates in a sort of tank dug in the mold. the water comes from a free space between the floor and the wall of the cabin (then that separates the cabin from the bathroom). Anyone else had the same issue and resolved? As soon as I can I put some photos to explain better Thank Hanse 375 - 2009
Edited by Davide - 05 October 2025 at 10:33 |
Yoda
Joined: 23 September 2022 Location: Devon, UK Status: Offline Points: 88 |
Quote Reply
Posted: 05 October 2025 at 23:21 |
I used to get water there and eventually traced it to a leaking skin fitting under the sink. Is it defiantly rain and not water from the tank?
I fitted an inspection port under the toilet to access the space, dry it out and seal up the route taken by the water. |
H8jer
Joined: 14 September 2010 Location: Denmark Status: Offline Points: 1503 |
Quote Reply
Posted: 06 October 2025 at 18:28 |
Agree.
Leaks there were in my case the fresh water hoses that had a leak. Now I have the bad habit to look there for leaks, if the pump runs without anyone using water.
Jef-370
Joined: 28 February 2023 Location: Swiss Status: Offline Points: 28 |
Quote Reply
Posted: 24 February 2026 at 13:54 |
Hello, It took me months to locate the leak: it was at the base of the shower pipe, inside the counter mould. This leak only occurred when the shower was in use (rarely, or to clean the toilet). Good luck.
Ratbasher
Joined: 31 May 2017 Location: Cyprus Status: Offline Points: 818 |
Quote Reply
Posted: 24 February 2026 at 15:10 |
On mine it was the join from the hose to the fresh water pump outlet.
Post Reply
| Tweet |
