  New Posts New Posts RSS Feed - HELP us race our 311
Tremena View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tremena Quote  Post ReplyReply Direct Link To This Post Topic: HELP us race our 311
    Posted: 04 August 2005 at 10:13
We got our 311 in April and we sail/race her in Arklow Sailing Club in the South East of Ireland but we need some help about race trimming.
1. Use the self tacking jib or not?  We found it was too small off wind and have put on a furling genoa off another yacht and it seems to be better but we are not sure.
2. The 2-blade Saildrive Prop is fixed so when we are sailing should we have it in neutral or reverse?
And what gain should we expect if we invest in a folding prop?
3. Any other comments about trimming the main?  We have been used to a mast head rig and the larger main is new to us.
Alan & Gerry
Edited by Tremena
Magnus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Magnus Quote  Post ReplyReply Direct Link To This Post Posted: 04 August 2005 at 22:36
About the fixed/folding prop;
The fixed propeller makes less resistance if it is allowed to rotate. But it might be harmful to some engines to rotate without proper lubrication. I don't know how the Yanmar is in this respect.
In the Swedish handicap system (LYS) the difference between fixed and folding prop is 1% in average boat speed. I think that the difference could be larger in many conditions.
/Magnus
franko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote franko Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2005 at 08:32
Alan & Gerry,
At all but the slowest speeds speed a two blade fixed prop will produce less drag when locked in astern, especially if you can arrange for it to stop in the vertical position. i.e. with one blade in the 'shadow' of the strut. (When you learn how to do this please let me know ;-)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Magnus Quote  Post ReplyReply Direct Link To This Post Posted: 05 August 2005 at 22:51
Franko,
is your statement based on scientific grounds, or is is it just common knowledge (i.e. rumour)?
I read the results from a test performed by Volvo Penta which said that the drag redecued to 1/4 when the prop was allowed to rotate (which also seems reasonable). Unfortunately I'm not able to find the evidence at the moment...
/Magnus
Post Options Post Options   Thanks (0) Thanks(0)   Quote Magnus Quote  Post ReplyReply Direct Link To This Post Posted: 06 August 2005 at 23:13
And here is the evidence...
The diagram is from Volvo Penta, measured on their sail boat drive.
Y-axis i drag in N, X-axis is boat speed in knots.
Curves from top to bottom
3 blade fixed, locked
2 blade fixed, locked
3 blade fixed, rotating
3 blade folding
2 blade folding
Quite clear that rumour isn't always truth...
/Magnus
Post Options Post Options   Thanks (0) Thanks(0)   Quote franko Quote  Post ReplyReply Direct Link To This Post Posted: 07 August 2005 at 09:56
Magnus,
That is great. First time I have seen any proof of the relative resistances. I am going to eat my hat now.
Where is the curve for the 2 Blade fixed, Rotating?
What about the merits of feathering versus folding?
Can you let us have the link to the graph?
Skål         &n bsp;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tremena Quote  Post ReplyReply Direct Link To This Post Posted: 08 August 2005 at 11:59
Thanks for all the replies so far.  Peter Thomas has recommended the Kiwi feathering prop which certainly looks interesting.
No comments yet on the self-tacking jib?
gertha View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gertha Quote  Post ReplyReply Direct Link To This Post Posted: 16 August 2005 at 22:38
I have 140 gen plus 2 blade folding.
As stated to other message I have drop keel and this efects performance and I suspect fold prop was not my best buy.
The prop makes little difference except under power when we go .5 knot slower, I tell my self that I  am going faster when sailing with prop as it cost alump.
www.brunton-propellers.com have some interesting figures.
If you want a deal I would be happy so sell prop on and revert to original it cost £ 580 and is on yanma sail drive.
spec was 15x11 varifold and has only had 6 months use
simon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tremena Quote  Post ReplyReply Direct Link To This Post Posted: 17 August 2005 at 11:29
Thanks for that.
As a matter of interest did you find any difference in performance over the 140 jib and the self-tacker jib?
mqh7 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mqh7 Quote  Post ReplyReply Direct Link To This Post Posted: 17 August 2005 at 15:37
I know on my 311 when I got rid of my fixed prop and put on a folding prop I had 3/10th of a knot better speed.
And I get good speed out of the self tending jib so I stay with it.  Now, I sail in a very windy area so I have no real need for a large head-sail.
This page was generated in 0.332 seconds.
