  New Posts New Posts RSS Feed - how to rig a barber hauler
panos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote panos Quote  Post ReplyReply Direct Link To This Post Topic: how to rig a barber hauler
    Posted: 31 May 2011 at 18:05
I took some pictures of the upwind barber hauler. The arrangement gives one more trimming line and a few degrees upwind can be achieved.
Edited by panos - 31 May 2011 at 19:31
Panos
Hanse 630e - selling her -
greeksailor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote greeksailor Quote  Post ReplyReply Direct Link To This Post Posted: 08 July 2011 at 14:07
you have problem with tacking?
holby View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote holby Quote  Post ReplyReply Direct Link To This Post Posted: 18 July 2011 at 18:48
Panos,
Thanks, that is similar to what I have set up on my 301, it helps quiet a lot.
haggy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote haggy Quote  Post ReplyReply Direct Link To This Post Posted: 23 November 2011 at 18:07
I stumbled on this topic, because I was thinking of using the same system you use, but more in putting the jib more outward, whilst sailing down wind, where the angle of the self tacking system is not ideal.
By correcting the angle of the sheet vs jib more outward, it could improve performance.
What is your experience?
Best Regards,
Marc
TAIMA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TAIMA Quote  Post ReplyReply Direct Link To This Post Posted: 24 November 2011 at 22:06
On my boat I installed two additional stoppers on the selftacking track, one on each side. This allows to reduce the tacking angle (the same panos achieves with his system) and while sailing downwind on light air you avoid the sail from going from one side to the other without control, because you lock the sail in on one side.
For sailing halfwind with an open jib just use a "shortsheet" with a block on an eyepad and ease the sheet.
Thomas Pollehne
Hanse 630/06 TAIMA
Rubato View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rubato Quote  Post ReplyReply Direct Link To This Post Posted: 25 November 2011 at 22:10
Best Regards,
Marc
Marc,
I've done what you suggest with the spinnaker guy. I have blocks placed on the toe rail pretty much where the shrouds are. These are normally used for the spinnaker guy while racing downwind. However, they come in hand for cruising where I attach the line to the self tacker to better off wind sail trim as you suggest....
Hanse 400e, #168
Post Options Post Options   Thanks (0) Thanks(0)   Quote haggy Quote  Post ReplyReply Direct Link To This Post Posted: 26 November 2011 at 14:49
Thank you for your information!
I'm gonna give it a try.
Good sailing!
Marc
JohnA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnA Quote  Post ReplyReply Direct Link To This Post Posted: 27 November 2011 at 11:39
What a good idea. I'm going to try it on our Hanse 320!
John
Hanse 320 #464 'Discovery'
Vadim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vadim Quote  Post ReplyReply Direct Link To This Post Posted: 11 December 2011 at 15:40
We are have put few stop - track.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Vadim Quote  Post ReplyReply Direct Link To This Post Posted: 11 December 2011 at 15:41
