  New Posts New Posts RSS Feed - Fuse Panel / Eberspächer Heater
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fendant Quote  Post ReplyReply Direct Link To This Post Topic: Fuse Panel / Eberspächer Heater
    Posted: 30 October 2014 at 09:39
Does anybody know, where the Hanse Yard has hidden the fuse panle with th 5 A and 20 A fuse for the Eberspächer heater? Any hints are highly appreciated.
Peter-Blake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Peter-Blake Quote  Post ReplyReply Direct Link To This Post Posted: 30 October 2014 at 12:16
I think you should follow the cable ;-)
Hanse used to build some fuses into the cables somewhere in the boat.....
Special about the eberspächer heater is, that it must have a totally own circuit! You will not find a switch in the main panel in your navstation. That is because the heater should not be turned of accidently by the mainswitch of the boat! The reason is simple: A heater always runs a shut down procedure when you stop it. This way it needs for about 4-5 minutes still some electrical power for this process!
Blake 370
Gordon Harrison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gordon Harrison Quote  Post ReplyReply Direct Link To This Post Posted: 31 October 2014 at 08:50
Have you looked under the chart table, the fuses are solid colour, in their own little holder, at least they have been on the the last two units I have had.
Gordon
skipper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipper Quote  Post ReplyReply Direct Link To This Post Posted: 31 October 2014 at 15:06
We have our Webasto fuse mounted in the battery box.
Cheers,
Skipper
Former owner of Hanse 342 2005 (Sparcraft mast, white hull, wheel steering, deep draft keel, short rudder)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fendant Quote  Post ReplyReply Direct Link To This Post Posted: 05 November 2014 at 15:17
Gordon was right! Thx very much indeedThumbs Up
The fuse holder is located portside between the power board under the chart table and the battery charger.
alettaenmarcel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alettaenmarcel Quote  Post ReplyReply Direct Link To This Post Posted: 24 January 2015 at 05:39
Eberspacher delivers it in the cable on every system, also on a car.
This page was generated in 0.160 seconds.
