  New Posts New Posts RSS Feed - Ceiling rocker light switches - 461
anteaterblues View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote anteaterblues Quote  Post ReplyReply Direct Link To This Post Topic: Ceiling rocker light switches - 461
    Posted: 11 January 2018 at 03:34
Hello all,
The Hanse 461 2005 model has grey 60mm square ceiling switches for activating lights in each of the cabin/head areas.
Some of these switches are failing. The plastic hinge for the rocker plate has lost it's hinge point. I was hoping to purchase a click in replacement unit rather than rebuild the existing failed plastic part.
I have failed to find any substitute replacement switches using popular search engines.
Has anyone else had the issue of failing ceiling switches and successful strategies for replacing them?
Kind regards
Kirk
Anto View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anto Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2018 at 13:15
Hello Kirk
Do you have discover the replacing ceiling switches? I need also.
Kind regards
Best regards
Antonio
H470#138
Post Options Post Options   Thanks (0) Thanks(0)   Quote anteaterblues Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2018 at 23:32
The local dealer in Australia has access to the double switch configuration, not the single switches. I ended up purchasing after market 12 volt rocker switches that have a stainless backing plate. They look similar in style to the lights that we have.
Kirk
Will461 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Will461 Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2025 at 09:54
Hello
I have a 461 2005 and need to replace main cabin ceiling rockerlight switches approx each 52mm square
anyone have info i'm in Italy
thanks
Bill
Edited by Will461 - 28 March 2025 at 10:22
This page was generated in 0.234 seconds.
