Forum Home Forum Home > Hints & Tips > 325
  New Posts New Posts RSS Feed - CALIRA sealine Panel 210 Hanse - PROBLEM
Anna164 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anna164 Quote  Post ReplyReply Direct Link To This Post Topic: CALIRA sealine Panel 210 Hanse - PROBLEM
    Posted: 17 August 2020 at 22:11
Good day
Our boat HANSE 325 number # 164 manufactured in 2013 has a CALIRA sealine Panel 210 Hanse. For six years everything was fine. A week ago we changed the starter battery and a few days after that a problem with the CALIRA panel was revealed. We don't know if these events are related, but now the panel does not work as it did before:
- fuel amount indicator # 1 # DOES NOT work
- battery charge indicator # 3 # began to show THREE batteries, although there are actually two of them (there is no thruster in the boat)
- the display does not decrease its brightness as written in the instructions - it always burns as brightly as possible
-button for turning off the Main Switch # 6 # panel, when pressed for a long time, displays the word "delated" and after that no buttons # 2 # and # 3 # and # 6 # work anymore. To make them work again, you need to physically disconnect all power with the Hauptschalter switch
Please help us to solve the problem. Is it possible to somehow completely reboot the system to fix these errors?
Thank you in advance for your help
Anna&Vlad
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fendant Quote  Post ReplyReply Direct Link To This Post Posted: 18 August 2020 at 07:00
Hello Anna,
as far as I know the 2013 built models do have the brownish grey Würth panel aand not the black Calira.
Do you have switches or push buttons ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anna164 Quote  Post ReplyReply Direct Link To This Post Posted: 19 August 2020 at 18:45
Dear Fendant!
Here is our black Calira panel
We have push buttons for fuel and water indicators
Anna&Vlad
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fendant Quote  Post ReplyReply Direct Link To This Post Posted: 19 August 2020 at 21:47
Sorry Anna, I do not have any details about this panel. Did you check "wesailhanse.se" ?
There is a ton of info also on older models.
Good Luck
Carlosailfan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carlosailfan Quote  Post ReplyReply Direct Link To This Post Posted: 20 August 2020 at 06:36
Hello Anna,
i have the same panel working fine, a small suggestion and i don't know if this will help but what happens if you turn of the main battery switch for a while ans start up again ? ( some kind of soft reset ) .
Best regards
/C
Post Options Post Options   Thanks (0) Thanks(0)   Quote Captain Cook Quote  Post ReplyReply Direct Link To This Post Posted: 20 August 2020 at 09:12
Look at page 28 in your User Manual. (It can be downloaded from the internet).
Here you find contact info for Calira.
This panel has to be sent to the factory for service.
Start with an email, and ask for advice.
This page was generated in 0.134 seconds.
