  New Posts New Posts RSS Feed - Fitting Auto pilot
Fitting Auto pilot
robh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robh Quote  Post ReplyReply Direct Link To This Post Topic: Fitting Auto pilot
    Posted: 19 April 2017 at 05:01
Hi all,
I am upgrading instrumentation on Blue Horizon to Raymarine this year to include the Evolution autopilot with ACU200 & EV1 sensor. I have been advised to use the Jefa LD100 linear drive instead of the Raymarine one as my wheel steering is Jefa and this makes the job easy.
The job looks straightforward:-
Fit a tiller arm on the opposite side of rudderstock to current wheel fitting for the drive attachment.
Remove one of the internal mouldings from the back of either the port or starboard rear cabins to gain access to the area under the binnacle (this will involve cutting out the cover currently held in place with screws and sikaflex then restoring this after).
Run in and connect the appropriate cables.
Has anyone done this retrospective fitment and can offer me any advice?
Thanks in advance, all offerings gratefully received.
Rob
"Blue Horizon" Hanse 341#113 Portsmouth Harbour UK
skipper View Drop Down
Vice Admiral
Vice Admiral
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipper Quote  Post ReplyReply Direct Link To This Post Posted: 19 April 2017 at 12:09
I would suggest you to SEARCH on MyHanse and you should find several installations of Jefa directdrive.
Skipper
robh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robh Quote  Post ReplyReply Direct Link To This Post Posted: 20 April 2017 at 03:54
Thanks for the tip Skipper, I will do that.
Rob
echoofwight View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote echoofwight Quote  Post ReplyReply Direct Link To This Post Posted: 21 April 2017 at 09:28
Hi Rob. I have replaced all my instruments over time. To gain access to the area beneath the binnacle I fitted a lightweight deck-hatch upside down into the moulding in the rear cabin. This looks very neat and makes any future access very easy.
robh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robh Quote  Post ReplyReply Direct Link To This Post Posted: 30 April 2017 at 15:51
Thanks Steve that sounds like a brilliant idea. Have you fitted a round one or square and is this in the side of the molding or the bottom?
I am not sure how much space I will need and exactly where to fit the Jefa linear drive, so I am a little hesitant to just cut anywhere before I know locations to avoid.
Rob
Post Options Post Options   Thanks (0) Thanks(0)   Quote echoofwight Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2017 at 09:23
Hi Rob,I fitted it on the bottom directly under the pedestal. It's a square hatch. Echo has one aft cabin so the pedestal is to the starboard side of the bulkhead. Fitting it makes running cables to the pedestal very easy. Where are you going to fit the drive?
robh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robh Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2017 at 13:49
Hi Steve,
Thanks for the feedback.
I have twin rear cabins and the bulkhead appears to run along the centre line, which gives me two covers, one in each cabin about the same size. Without knowing the exact layout beneath the cockpit I have taken a few photos, which suggest the centre bulkhead does not intrude into that space giving a void roughly the width of the raised section of the cockpit floor.
I hope to fit the drive on the port side of this void, so I am considering cutting a hole in the port side of the rear bulkhead about the same size as the one on the starboard side about the same distance from the centre line. This will enable me to bring the operating arm through into the rear locker and attach to the second tiller arm located above the current one. The intention is to fit the fixed base part of the drive in that void the other side of the wheel. I need to take work out where best to cut the hatch so I have solid material to locate the drive. Current thoughts are this should be at the very back of the cabin trim/cover, so I don't encroach on any space for the drive and as big as possible to give max working room.
If you have accessed that space can you tell me if there is a solid section of bulkhead where I could mount the fixed end of the drive or would I need to glass something in for this? What size hatch have you fitted, square or round?
Any further info you could supply would be very helpful.
Rob
robh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robh Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2017 at 14:01
Sorry I asked again if square or round when you had said square in your reply. I have also just had a look at my pictures and it looks like the bulkhead, as on your boat does go to the cockpit floor, as I can see the wires going into the pedestal. This makes me think there is a similar space the other side of the bulkhead which I can access from the port cabin, strange how things looks so different when you are hanging upside down trying to look at spaces. Looks like I may have to fit a hatch in that side to locate and gain access to the drive.
Rob
Post Options Post Options   Thanks (0) Thanks(0)   Quote echoofwight Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2017 at 10:13
Hi Rob, if you are in Portsmouth you could come and take a look.
robh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robh Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2017 at 11:12
That would be great, thanks for the offer.
I live in Hertfordshire so a quick drop in is not possible, however, will be down at the boat from next Saturday for a few days so if you are about and its not inconvenient I could come take a look then.
Where are you berthed?
Rob
This page was generated in 0.070 seconds.
