  New Posts New Posts RSS Feed - Shower mixer Hanse 400
jeb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeb Quote  Post ReplyReply Direct Link To This Post Topic: Shower mixer Hanse 400
    Posted: 30 May 2018 at 06:26
The shower mixer in my Hanse 400e from 2006 has started to leak (from the front).
There are 2 options on boatoon.com.
1) Shower Mixer control in set @20€
2) Single lever shower @68€
Does any one know if option 1 is enought?
Jesper
Hanse 400e
neilbay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote neilbay Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2018 at 06:35
I have just replaced mine, the sleeve had cracked.
I used the TSF1372 as it was a direct replacement. It would be quite a struggle to replace the whole unit. Which would be required if you went with option 1
I managed to unscrew the lever part of old unit, leaving the base and pipes, then put the new piece on.
I did have to figure out how to remove the cover etc to get the holes lined up when fitting the new unit.
Hanse 400 2007 - Back in NZ
Old Racer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Old Racer Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2018 at 16:39
We had a leak in ours and it turned out to be the ceramic cartridge in the inside of the tap itself.
Cost only a few pounds to replace.
John
Hanse 320 Olicana Inverkip Scotland
Post Options Post Options   Thanks (0) Thanks(0)   Quote Old Racer Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2018 at 17:19
There are plenty of you tube videos that show you how,
The top came off using a soft wrench (cheap to buy) .
jeb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeb Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2018 at 15:06
Thanks for the advises. John, where did you source the ceramic cartridge. I guess they are unique for all taps and the Reich brand is not that common i Sweden.
Jesper
Hanse 400e
Post Options Post Options   Thanks (0) Thanks(0)   Quote Old Racer Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2018 at 15:22
I sourced them from a local DIY shop. They appear to be generic I took the old one out first to compare.
The other thing one of the videos suggested was just cleaning and reseating the cartridge and see if that cures it before buying a new one.
I got mine in Homebase not sure what stores you have in Sweden.
From memory it was the 35mm model as per the link
Hope this helps
John
