Connection to Isotherm water heater |
Ian
Sub Lieutenant Joined: 26 March 2016 Location: UK Status: Offline Points: 3 |
Posted: 11 June 2018 at 12:13 |
Hi Guys,
I need to replace one of the 15mm connectors on the inlet side of my water heater. The 15mm semi-rigid water pipe on my 2006 370 is not common in the UK. Any ideas would be appreciated. Thanks Ian |
Ggerrit
Commander Joined: 19 June 2016 Location: Monnickendam Status: Offline Points: 149 |
sent me a pm ; if you know what you need exactly... I think 1/2"inside to 15 mm
jeb
Captain Joined: 05 May 2014 Location: Sweden Status: Offline Points: 226 |
I have the same issue. The tube is a german "standard" AluPex and I have tried to find fittings with no sucess. Right now I have a normal heat resistant hose mounted on the outside of the pipe but is has developed into a leakeage between the pex and alu part. If any one knows where to get the fitting that fit to the original pipe I would be happy to know.
Jesper
Hanse 400e |
iemand
The manufacutrer is IVT Prineto.
BR Thomas
sflier
Commander Joined: 18 October 2013 Location: Newport, RI Status: Offline Points: 95 |
That's a 1/2" BSP British fitting. The gasket should be fiber if original. As stated above it's a Prineto tube and fitting from Italy. Search my posts and you'll find a link to more information including a link to their catalog.
MarcoC
Admiral Joined: 23 April 2009 Location: Sweden, Stockh. Status: Offline Points: 1617 |
Please look into Pex tube - crimp ring fitting on youtube. In Sweden we use connectors like this https://www.bauhaus.se/vvs-och-installation/rorinstallation/pexkopplingar/klamringskopplingar-pex-15-mm.htmlI believe these are better than the pressed ones as they are easier to replace.
Im going to replace my heather soon and I will also consider to have a ball valve in order to make next change easier. Marco
"Älva"
Hanse 370#671 Stockholm, Sweden www.wesailhanse.se big wheel, deep draught iron keel, 3 cabins,Yanmar 3JH4E, Sparcraft rig. |
Ian
Dear All, Thank you for the help. Happily, by adding an extra fibre washer I was able to seal the connection temporarily. When the season is ended I will be able tackle the job properly. Regards Ian
