Strengh rudder axcis Aluminun |
Author | ||||||||
812
Sub Lieutenant Joined: 12 December 2014 Location: Germany Status: Offline Points: 10 |
Posted: 16 November 2018 at 22:12 |
Hi, having galvanic Problems with my Aluminium rudder axcis on our H 375 I would like to know something about the strengh of this rudder axcis. Can someone tell me how thick the walls on that pipe is? Is there any experience in the Group dealing with this Subjekt?
Carsten
alettaenmarcel
It aint a pipe!
It is a masive alu . See the jefa website. The rudder in total weights about 52 kg and the masive alu stock itself weights about 36 kg. |
Ratbasher
Rear Admiral Joined: 31 May 2017 Location: Cyprus Status: Offline Points: 591 |
This forum has a lot of comment about this. When I bought my 2008-model boat two years ago I noticed a fair amount of pitting. The surveyor said it was nothing to worry about and the main UK Hanse dealer echoed this, showing me a 'spare' rudder post to show how massive a structure it is. Apparently its only the visible 2cm part of the stock that corrodes. However, I didn't agree that it was nothing to worry about, especially as other issues with corrosion became evident later. Although the rudder post is supposed to be electrically isolated, the experience in this forum suggests that this may be hard to achieve in practice. Last year I fitted a hull anode and bonded both the rudder post and the saildrive leg to this as I'd also had problems with the leg's anode being eaten rapidly. This year there's been no further (visible) pitting on the rudder post and the SD leg's anode has lasted so much better, while the hull anode has depleted nicely showing that its doing its job properly. The rudder post is indeed massive and I'm not concerned about its integrity. However, I'll be keeping a very close watch on the post, saildrive and anodes.
Carlosailfan
Captain Joined: 06 March 2014 Location: Belgium Status: Offline Points: 193 |
Hello, there are a lot of opinions on this but galvanic corrosion is an issue even on GRP boats. I installed a separate anode only connected to the rudder, one only connected to the saildrive and another only for the keel. Yes I made a few holes but the result great, no oxidation, no rust, nothing any more. Only partly eaten anodes what is fine.
Best regards
/C |
Sea-U
Commadore Joined: 14 September 2012 Location: Norway Status: Offline Points: 459 |
Jefa says that we should paint the exposed part with epoxy. I think that will help a little.
redlion
Captain Joined: 28 August 2013 Location: Creran Scotlan Status: Offline Points: 188 |
I use the same spray paint I use on the saildrive https://international-yachtpaint.com/en/gb/boat-paint-products/antifouling/trilux-prop-o-drev .It appears to work well and is easy to apply.
StavrosNZ
prop speed for both prop itself and aluminium leg is an excellent option, if applied properly it lasts a long time and provides a coated protection to the material its applied to.
Stephen
812
Hi, thank you very much to all of you, this is what Jefa said, on top there are very interesting links: Dear Michael I have seen this before, read the bulletin from Hanse, attached. Your rudder stock is made in solid aluminium 6082, and I don’t think the problem is so deep, that it can’t be repaired. The stock can be fixed with a sleeve and a bigger bearing. This will cost €.420,- +VAT https://jefa.com/products/sleeves/sleeves.htm https://jefa.com/ftp/rudder/Bearingballs/M13-248-92.PDF This will stop the problem, but the loss of strength will not come back. You have to check if any electricity is connected to the stock. That’s the reason for the corrosion. https://jefa.com/install/electro.htm Drawings: https://jefa.com/ftp/old_boat_spare_parts/Hanse/Hanse_375/ (hanse 405, 375 and moody 41, use the same rudder) Med venlig hilsen / Best regardsJan Faurschou Sales and Service Representative |
Carsten
Scottie
Sub Lieutenant Joined: 26 January 2011 Location: United Kingdom Status: Offline Points: 16 |
Did you get any outcome with this problem ?
812
Hi Scotti, yes there is an outcome in process. We recieved following answer from Jefa. (see below). quote Jefa: I have seen this before, read the bulletin from Hanse, attached. Your rudder stock is made in solid aluminium 6082, and I don’t think the problem is so deep, that it can’t be repaired. The stock can be fixed with a sleeve and a bigger bearing. This will cost €.420,- +VAT https://jefa.com/products/sleeves/sleeves.htm https://jefa.com/ftp/rudder/Bearingballs/M13-248-92.PDF This will stop the problem, but the loss of strength will not come back. You have to check if any electricity is connected to the stock. That’s the reason for the corrosion. https://jefa.com/install/electro.htm Drawings: https://jefa.com/ftp/old_boat_spare_parts/Hanse/Hanse_375/ (hanse 405, 375 and moody 41, use the same rudder) The new rudder stock bearing (for rudder with sleeve) fits into the existing housing, in other words, is the existing housing as well 130 mm diameter? Med venlig hilsen / Best
regards
Carsten
