Rudder Bearings 371 |
Cassiopeia
Sub Lieutenant Joined: 13 December 2018 Location: Marina del rey Status: Offline Points: 3 |
Posted: 31 July 2019 at 18:38 |
Does anyone know where I can get new bearings? Have you ever had to replace your bearings?
samuel
https://www.jefa.com/rudder.htm Top bearing should be easy enough to replace whole part. Bottom bearing should just be a case of replacing the rollers. But contact Jefa for advice Edited by samuel - 01 August 2019 at 07:15 |
Cassiopeia
Thanks...I will contact them.
jeb
Captain Joined: 05 May 2014 Location: Sweden Status: Offline Points: 226 |
i did this a couple of years ago on my previous boat, Hanse 371 from 2004. It was not that easy to remove the rudder. The bottom bearing is self aligning, but top bearing is not. On the 2004 model the surface where the top bearing is mounted is not 90 deg to the rudder stock and it got stucked. I needed to unscrew the bolts securing the top bearing to be able to get it out. Top bearing is also fixed with sikaflex but this will flex enough to get the bearing aligned with the rudder stock. When re-installing the rollers, use a baloon to keep them in place until you can install the outer ring that secures the rollers.
Edited by jeb - 06 August 2019 at 22:02 |
Jesper
Hanse 400e |
Trevor_N
Sub Lieutenant Joined: 06 August 2022 Location: UK Status: Offline Points: 16 |
Hi, I am replacing the rudder on my Hanse 371. Can you tell me if you removed the lower bearing. I have seen that it self-aligning, but I cannot get it to move in the spherical housing to remove it.
Any advice? Thank you
Trevor - UK
redlion
Captain Joined: 28 August 2013 Location: Creran Scotlan Status: Offline Points: 188 |
Push the end of the rudder shaft into the bearing and move it around to get it loose then align the bearing with the slot on the bearing housing and pull it out and give it a good clean. Mine had 2 rubber o rings that had to be replaced ( 3mmx 110. NBR from simply bearings) . As I recall there is a link to a video on the Jeffa website that was very helpful.
Thinking back, I used the handle end of the boathook to loosen the bearing.
Trevor_N
Thanks, that's the best advice I have had on this, really helpful. I will see if I can get the ball to rotate as you suggest.
Trevor - UK
redlion
The Video (48) Jefa Rudder and bearing service - YouTube
This is a service guide on how to maintain Jefa Marine rudder bearings. This should be done every third year.
The video is made with a Hanse 325. The principle is the same for all Jefa Marine products. MMM, every third year??? I wonder how many people do that?
Trevor_N
Thank you
Trevor - UK
Gale Force
Captain Joined: 26 June 2018 Location: Sri Lanka Status: Offline Points: 278 |
A superb video which casts a light on what I have been going through recently and puts a lot of common sense into the whole steering mystery and highlights the need for careful maintenance programmes to be adhered to.
Many thanks for posting Duncan
