Forum Home Forum Home > Hints & Tips > 355
  New Posts New Posts RSS Feed - How to operate the waste tank?
Nyholm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nyholm Quote  Post ReplyReply Direct Link To This Post Topic: How to operate the waste tank?
    Posted: 09 September 2019 at 21:13
I just bought a Hanse 355, 3 cabin. How do I open/close the waste tank?
Hanse 355, 2011
Post Options Post Options   Thanks (1) Thanks(1)   Quote S&J Quote  Post ReplyReply Direct Link To This Post Posted: 09 September 2019 at 21:45
The holding tank is simply operated by the sea cock below it.
There is no Y-valve so once you start using it, you need to continue using it until you can empty it.
It is only about 35 litres so can fill quickly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nyholm Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2019 at 20:30
Simple - Thanks
If it overflows where does outlet go? Into the boat or outside?
Hanse 355, 2011
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wayne's World Quote  Post ReplyReply Direct Link To This Post Posted: 10 September 2019 at 22:08
Nyholm,
There is a overflow outlet on the outside of the hull near where the sullage tank is located about 20cms below the deck level. If the tank overflows sullage will run down the outside of the hull from this overflow outlet. These can become clogged up so it might be worthwhile unscrewing the cover on the outside of the hull and checking the outlet is not clogged up.
