Internal car in the boom |
Post Reply
| Author | |
sailingfree
Commander
Joined: 20 May 2007 Location: United Kingdom Status: Offline Points: 103 |
Quote Reply
Topic: Internal car in the boomPosted: 17 March 2021 at 18:16 |
Hi, On Draghonfly (301 2002) the outhaul is connected to what looks like in internal 2:1 car inside the boom. The outhaul has now worn to the point I need to replace it, but I can't work out how it is rigged. I think I have to take the end caps off the boom and while I'm at it I'm thinking of removing the car as there is a ton of friction in the outhaul, and just lead the outhaul back to the cockpit. Has anyone dismantled the boom and knows whats inside? I can't find anything on the Sparcraft website either. Thanks Pete
Taylor
Joined: 02 December 2013 Location: North Wales Status: Offline Points: 180 |
Quote Reply
Posted: 18 March 2021 at 09:45 |
I will check mine out today and feedback.
I am not sure we have any car for outhaul.
Friction not a problem other than with the line running over the deck from the front organisers to the clutch. Hope to explain with a photo. Steve. |
Hanse 301 Bluenote 11
iemand
Joined: 13 February 2004 Location: Germany Status: Offline Points: 1099 |
Quote Reply
Posted: 18 March 2021 at 11:15 |
which brand of boom do you have? Selden has such car, Sparcraft not as far as I know
sailingfree
Commander
Quote Reply
Posted: 18 March 2021 at 18:09 |
Hi, thanks for the feedback. I took the ends off the boom and fished the outhaul out. It's not a car, just a standard double block and lots of rope. The block looks OK so I think the friction is in the sheaves in the boom ends. It is a Sparcraft part so I'm guessing it came as standard. Since its a standard part , and it does make mainsail shape easier to control I'm going to keep this. ![]() |
sailingfree
Commander
Quote Reply
Posted: 18 March 2021 at 18:16 |
Hi Steve, I had the same problem with friction in the halyards and reefing lines when I first got Dragonfly back in 2007. To resolve this I added some teak blocks under the turning blocks to raise them up as described in this post: https://www.myhanse.com/friction-in-running-rigging_topic1411_page2.html?KW=friction
mjo
Lieutenant Commander
Joined: 17 May 2016 Location: Baltic Sea Status: Offline Points: 55 |
Quote Reply
Posted: 12 April 2021 at 20:00 |
Post Reply
| Tweet |
