Halyard Winch/Windlass Battery |
Carlwasher
Lieutenant Joined: 31 August 2020 Location: Elh/1000 Island Status: Offline Points: 28 |
Posted: 08 April 2021 at 16:17 |
Can anyone tell me if the halyard winch is wired to the house batteries or the Windlass Battery
TIA
H8jer
Admiral Joined: 14 September 2010 Location: Denmark Status: Offline Points: 1347 |
In our 2008 370 the cockpit winches are connected to the windlass batteries.
The circuit breakers/auto-fuses are in back of starboard aft cabin The two haleyard winches are non-electric on our boat. /h8jer
Edited by H8jer - 08 April 2021 at 18:35 |
Carlwasher
Thank you for your response
Are you running your windlass & winches off a deep cycle battery?? I am working with Ocean Planet on a power configuration and they recommended to you a combination battery NOT a deep cycle.
H8jer
I have 2x105ah leadAcid. They are old, but they are not drained much.
Will add battery monitor for those batteries this year. They power the 3000w thruster so high cranking power is needed. Think that is why I have 2.
Edited by H8jer - 14 May 2021 at 15:06 |
Peter Russell
Commadore Joined: 24 October 2007 Location: Wiltshire Status: Offline Points: 430 |
On my 2008 model the electric halyard winch is on the house batteries. Subsequent to delivery I modified the electric windlass battery to be part of the house bank. The engine on relay is still in place so I can't see any issues with excessive draining, but it does give quite a few usable added Ah to the boat
H8jer
I have now installed a battery monitor for the two windlass/winches batteries.
They are not used very much. But the cranking power needed is surprisingly high. When I tried the 3000w thruster I saw 425A for a brief moment. A bit strange because the large fuse is 200A I would like to change the 2x105ah (50kg in total) to lipofe4 and let them join the house battery bank. But with these currents I think I will keep the setup because high cranking Lipofe4 are a bit more espensive than the 3 lipofe4 100AH (max 100A CCA) I have now.
