Forum Home Forum Home > Hints & Tips > 371
  New Posts New Posts RSS Feed - Replace hinge for easy door removal?
Laro88dk View Drop Down
Lieutenant
Lieutenant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Laro88dk Quote  Post ReplyReply Direct Link To This Post Topic: Replace hinge for easy door removal?
    Posted: 02 August 2023 at 19:30
Any chance that the later models have hinges that makes it possible to lift the door off?
I would like to just to make it easier to access the engine and gearbox.
Perhaps the later ones have easier ehinges.
Jes hull#70
samuel View Drop Down
Admiral of the Fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote samuel Quote  Post ReplyReply Direct Link To This Post Posted: 03 August 2023 at 18:26
You need lose pin hinges.
ThomasKK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ThomasKK Quote  Post ReplyReply Direct Link To This Post Posted: 12 September 2023 at 08:08
Yes, I think later ones are liftable.
Our boat is hull nr. 186 and I usually lift doors away when needed to do something.
-tkk
Lieutenant
Lieutenant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Laro88dk Quote  Post ReplyReply Direct Link To This Post Posted: 01 November 2023 at 20:48
I ended up grinding the hinge a bit to be able to get the pin out, then polish/grind ~1/10mm off the pin to make it drop in again smoothless. I put a 2mm o-ring on the top to make it easy to lift with a pinky nail :-)
Takes 1-2 hours pr door.
Jes, DK, 370e #326
This page was generated in 0.133 seconds.
