Forum Home Forum Home > Hints & Tips > 325
  New Posts New Posts RSS Feed - Water coming into the middle cabin celling
Jan_B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jan_B Quote  Post ReplyReply Direct Link To This Post Topic: Water coming into the middle cabin celling
    Posted: 22 September 2023 at 12:54
I am new to the forum, but I hope to get some input on a problem. I have on a Hanse 325 and discovered water coming into the middle cabin celling (see picture). The location of the leak is between the two small plates that surround the support pool for the mast. There has been heavy rain in the areas the day before I came onboard and discovered the leak. I have some question I would appreciate to get some feedback on
-          - Do any other in the forum experience such a leak? In case yes what was the cause?
-          - I think I need to remove the two plates for inspections, do anyone have a god approach how to remove them?
BR
JB
Jojo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jojo Quote  Post ReplyReply Direct Link To This Post Posted: 22 September 2023 at 15:34
Those panels are removable to disconnect/connect cables to the mast
My guess is the swan neck or the mast foot is leaking if you get water in that way you check the aft cabin hatch as it’s sometimes bad seal from the factory
When removing those panels dry it carefully then get a helping hand to spray water round the mast foot and swan neck preferably not a pressure washer as that may cause more leaks
Regards jonas
Edited by Jojo - 22 September 2023 at 15:40
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jan_B Quote  Post ReplyReply Direct Link To This Post Posted: 23 September 2023 at 16:46
Hi Jonas
Thank you for the reply. I did as you recommended; removed the panels and used a water hose to spray around the hatch, mast foot and the goose neck. No water leakage was spotted. Only when we sprayed into the goose neck. I assume that the bad weather and unfavourable wind lead the water in trough the goose neck. It is a new boat for me, so I don’t have much experience with it. But I had the last owner with me on the test and he claimed that he has never seen such a leakage. He used ta different marina where the intake of the goose neck has been protected for direct wind. The wood on the panel was in perfect condition, so I assume that this has not been a problem earlier. Have anyone on the forum made a modification on the goose neck to prevent this from happening? The quick fix now was a plastic bag over the goose neck, but I am looking for something more professional.
Best regards
Jan
Merinalle View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Merinalle Quote  Post ReplyReply Direct Link To This Post Posted: 23 September 2023 at 18:01
We have had similar problem. I changed the goose neck to a bigger one a couple of years ago, and now it is much easier to handle the cables. At first, I though it is a good way to improve the ventilation through the deck, too. Unfortunately, we got water in during heavy rains. Nowadays, we put a piece of plastic foam inside the goose neck after installing the cables.
320#166
Old Racer View Drop Down
Commander
Commander
Post Options Post Options   Thanks (0) Thanks(0)   Quote Old Racer Quote  Post ReplyReply Direct Link To This Post Posted: 24 September 2023 at 16:45
I had this problem on our 320. The cause was water running over the cables and when windy being blown through the swan neck and into the area you highlight.
I tied cable ties at different positions on the cable to break up the flow of water and put tape over the opening of the swan neck.
Not a drop since.
Hope this helps
John
Hanse 320 Olicana Inverkip Scotland
Yoda View Drop Down
Commander
Commander
Post Options Post Options   Thanks (0) Thanks(0)   Quote Yoda Quote  Post ReplyReply Direct Link To This Post Posted: 24 September 2023 at 23:34
I found mine was leaking between deck and swan neck. I removed it, ground off the deck pimples and re sealed it. Leak fixed.
This page was generated in 0.225 seconds.
