Forum Home Forum Home > Hints & Tips > 350
  New Posts New Posts RSS Feed - Refrigerator lid hinges
Mark Pullen View Drop Down
Commander
Commander
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark Pullen Quote  Post ReplyReply Direct Link To This Post Topic: Refrigerator lid hinges
    Posted: 26 September 2024 at 17:40
Hi, has anyone fitted hinges to a counter top refrigerator lid?
Some crew are complaining about the weight of the lid, and hinges could work.
Any advice about drilling into the counter top would be appreciated - whether it has a wood backing, will a self tapping screw hold securely, etc...
Many thanks, Mark
Yoda View Drop Down
Commander
Commander
Post Options Post Options   Thanks (0) Thanks(0)   Quote Yoda Quote  Post ReplyReply Direct Link To This Post Posted: 26 September 2024 at 23:09
Yes I did on my 370. The Corrian top can be machined with a router just like wood. It needed a palm router, the correct size router bit and a template making up. Mine was done by a friend experienced with a router. I used a tap to allow the use of machine screws into the Corrian.
landlocked View Drop Down
Rear Admiral
Rear Admiral
Post Options Post Options   Thanks (0) Thanks(0)   Quote landlocked Quote  Post ReplyReply Direct Link To This Post Posted: 27 September 2024 at 17:03
I added hinges to my 400e lid (2006), and it is a great improvement.  The lid opens and rests against the cabinet knob which works great.   I used a dremel tool with a router attachment and a small bit and just routed out a recess for the hinge hardware (I didn't recess the hinge plates because I didn't want to reduce the thickness of the countertop material, and I think it works great this way).   I am attaching photos of the process but don't actually have photos of the finished product!  I made a template and used double-sided tape to hold it in place while doing the routing (you can see the routed recess in one of the pictures).  I carefully screwed the hinges down with self-tapping screws but I think tapping and using machine screws is an excellent alternative.
The ergonomics is very much improved with hinges on the lid.
"Kerkyra" 400e #042
Commander
Commander
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark Pullen Quote  Post ReplyReply Direct Link To This Post Posted: 29 September 2024 at 12:30
Thank you for your message. Very helpful and reassuring.
Commander
Commander
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark Pullen Quote  Post ReplyReply Direct Link To This Post Posted: 29 September 2024 at 12:33
Many thanks for your message. Very helpful and reassuring, particularly the detail about routing only hinge mechanism and not the plates. Seems like a useful modification.
Commander
Commander
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark Pullen Quote  Post ReplyReply Direct Link To This Post Posted: 30 March 2025 at 16:48
Hi Landlocked, do you know the approximate thickness of the Corrian and will it take a self tapping screw? Many thanks, Mark
Rear Admiral
Rear Admiral
Post Options Post Options   Thanks (0) Thanks(0)   Quote landlocked Quote  Post ReplyReply Direct Link To This Post Posted: 31 March 2025 at 16:04
Hi Mark:
My boat is a 400, not a 350 though I expect the thickness would be the same.  I’m not near the boat now but there are places where the edge is exposed (i.e. sink openings) and I would say it’s about 1/4 inch or 7mm.  Not very thick but I drilled through and used self-tapping screws (drill holes big enough to avoid cracking the material or shearing off the stainless screws).   I also applied sikaflex between the hinges and corian and in the screw holes.   No issues so far and it is much easier to use the fridge.
"Kerkyra" 400e #042
Commander
Commander
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mark Pullen Quote  Post ReplyReply Direct Link To This Post Posted: 31 March 2025 at 16:29
Perfect! Many thanks.
This page was generated in 0.075 seconds.
