Forum Home Forum Home > Hints & Tips > 345/348
  New Posts New Posts RSS Feed - Anti-Syphon Leak
Anti-Syphon Leak
Al 348 View Drop Down
Lieutenant
Lieutenant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Al 348 Quote  Post ReplyReply Direct Link To This Post Topic: Anti-Syphon Leak
    Posted: 30 March 2025 at 00:40
Dear Friends,
I own a 2022 Hanse 348 with a Yanmar 3YM30 diesel engine and SD-25 sail drive. Today I recommissioned after winterization.
The engine started right up with water from the exhaust exiting normally.
Then I noticed water in the engine compartment coming from a small tube connected to the anti-syphon system. One tube going from the heat exchanger to the anti-syphon, then one exiting the anti-syphon to the exhaust system and one tube coming from the anti-syphon to the open basin under the engine. This is where the water was coming from. I took the anti-syphon apart. There was no debris. I took out the valve, spring, and O ring, put it all back together and the leaking became worse.
Any advice?
Thank you in advance.
Al
Peace through Sailing
Arcadia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arcadia Quote  Post ReplyReply Direct Link To This Post Posted: 30 March 2025 at 02:06
Sounds like the valve in the anti siphon is not closing fully when under normal water pressure. It should only open when under suction. It can sometimes stick open, but that is what the spring is for. Any chance that it was reassembled wrong ?
Lieutenant
Lieutenant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Al 348 Quote  Post ReplyReply Direct Link To This Post Posted: 30 March 2025 at 02:21
It’s possible. I wonder where I can find a diagram of the anti-syphon system.
Thank you,
Al
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arcadia Quote  Post ReplyReply Direct Link To This Post Posted: 30 March 2025 at 02:30
I don’t know for sure about the 348, but Hanse usually uses the Vetus unit. Vetus may have a diagram on their website. The model is “AIRVENTV”.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arcadia Quote  Post ReplyReply Direct Link To This Post Posted: 30 March 2025 at 02:36
Lieutenant
Lieutenant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Al 348 Quote  Post ReplyReply Direct Link To This Post Posted: 30 March 2025 at 05:18
Thank you.
The diagram confirms that is how I reassembled the anti-syphon system. It is recommended to spray the valve with Teflon spray and I will try Sailcoat and let you know if that works.
Al
Tranquillity View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Tranquillity Quote  Post ReplyReply Direct Link To This Post Posted: 30 March 2025 at 18:22
If the clear antisyphon pipe is dripping into the bilge, cleaning the valve, spring, and assembly with fresh water normally does the trick to stop the drip!  However last year despite cleaning it still leaked so swapped the value and all was good again. The valve is incredibly expensive for what it is from Vectus but if you Google the part I found one for a fraction of the cost on the web.
Ratbasher View Drop Down
Vice Admiral
Vice Admiral
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ratbasher Quote  Post ReplyReply Direct Link To This Post Posted: 31 March 2025 at 15:42
Originally posted by Arcadia Arcadia wrote:
Try this.
Leon - many thanks for the link; most valuable.  This is another of those items requiring regular maintenance/replacement that aren't that well known at all, like the paddlewheel on the speed log that I discovered needed changing earlier.  My maintenance log is growing all the time!
Iain
Edited by Ratbasher - 31 March 2025 at 15:56
Lieutenant
Lieutenant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Al 348 Quote  Post ReplyReply Direct Link To This Post Posted: 31 March 2025 at 20:04
I did take the valve apart and cleaned it well with fresh water, made sure the spring and O ring were reassembled correctly as per the Vectus diagram and the leak is worse.
Apparently, there is a dealer in my area that I have contacted via the Vectus website and will obtain a new valve. I will also check the web as Tranquility suggested.
Thank you,
Al
samuel View Drop Down
Admiral of the Fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote samuel Quote  Post ReplyReply Direct Link To This Post Posted: 01 April 2025 at 10:58
I put the end of the small pipe into a 5 litre plastic container to collect the water drips. Then after each trip, or during a long motoring trip I just empty it down the sink. To prevent that syphoning back in to the engine when it is switched off, I have made a tiny hole in the pipe above the container level. I have the Volvo valve which is designed to drip continuously. But if the units nut is overtightened it will run quite hard. Salt build up also clogs the valve.
Edited by samuel - 01 April 2025 at 11:03
This page was generated in 0.405 seconds.
