Forum Home Forum Home > Hints & Tips > 430
  New Posts New Posts RSS Feed - Masthead Light
Masthead Light
Issywa View Drop Down
Commander
Commander
Post Options Post Options   Thanks (0) Thanks(0)   Quote Issywa Quote  Post ReplyReply Direct Link To This Post Topic: Masthead Light
    Posted: 16 July 2025 at 19:07
My anchor light is not very bright so I intend to replace it with a LunaSea Tricolor.
Yesterday afternoon a friend climbed the mast and cut off the old wires but reported that the remaining wires are very short and splicing on the new light may be problematic.
There doesn’t seem to be any slack in the wires - he was unable to pull any extra at the top of the mast. Nor could we get slack from the base of the mast.
Anybody know how the wires are (or aren’t) attached/run down the mast? Presumably there’s a conduit?
I note that when I replaced the electronics a couple years ago, I was unable to remove any of the existing wires and ended up reusing the radar and vhf cables. I also went with a wireless wind instrument for the same reasons.
Aussieangus View Drop Down
Commander
Commander
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aussieangus Quote  Post ReplyReply Direct Link To This Post Posted: 17 July 2025 at 06:24
No Idea mate but i know that my electrician had a similar problem but he was just able to connect the masthead light. Im guessing you could extend the length by adding some cable in inside the boat but then youve got a break in the line which isnt ideal.
Sydney Australia
GODS COUNTRY
Dogscout View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dogscout Quote  Post ReplyReply Direct Link To This Post Posted: 19 July 2025 at 22:27
Just last week I pulled a new VHF cable through the mast, from the top down.  I do not know how your mast is configured but mine appears to have 2 conduits.  One at the front has the VHF and Wind instrument.  The second (with the lights and radar cable) is on the port side just behind the hole in the base of the mast where the wires enter.  That is what I could discern from poking around through that hole.  If you can get a borescope attachment for a cell phone you may get a better picture.  I have not yet tried replacing any of the light connections.
Adventure awaits
Ian Coverdale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Coverdale Quote  Post ReplyReply Direct Link To This Post Posted: 20 July 2025 at 02:39
Is it ZSPARS?
Our 445 has two conduits. One from base to part way for radar, steaming light and deck light. Second from base to masthead for anchor light, VHF antenna and wind sensor. They are not big conduits so both are pretty congested.
We had mast off two years ago for standing rigging replacement so replaced some cables too. Used soapy water for lubrication but it still pretty difficult to pull cables through even with mast base completely open. The conduits unclips from the mast at the base easily then any movement makes further length unclip. It's all a bit fiddly.
Don't think we could have replaced the cables with mast in place.
Ian & Andrea
SV Gabrielle (H445)
Arcadia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arcadia Quote  Post ReplyReply Direct Link To This Post Posted: 21 July 2025 at 15:54
Just an FYI. For anyone replacing or working on mast cabling, I would strongly recommend changing to tinned cable. Those wires have a high exposure to salt air and moisture and Hanse like many production builders use less expensive untinned wire.
This page was generated in 0.117 seconds.
