Forum Home Forum Home > Hints & Tips > 415/418
  New Posts New Posts RSS Feed - Retrieving main sheet on Hanse 415
Ocean Lure View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ocean Lure Quote  Post ReplyReply Direct Link To This Post Topic: Retrieving main sheet on Hanse 415
    Posted: 30 November 2025 at 17:24
Have just purchased a Hanse 415.
There was no knot at the end of the main sheet and it ran back through the clutch back to the gooseneck.
I need to retrieve the sheet back to the clutch but it goes through a "tunnel" back to the clutch.
Is there an easy way to do this without removing the tunnel and half the bimimi?
Any help greatly appreciated
smfree
kipwrite View Drop Down
Commadore
Commadore
Post Options Post Options   Thanks (0) Thanks(0)   Quote kipwrite Quote  Post ReplyReply Direct Link To This Post Posted: 30 November 2025 at 19:08
Try a sail batten, some sturdy tape, and a boroscope-type camera.
Kipwrite
Matt1 View Drop Down
Rear Admiral
Rear Admiral
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2025 at 07:08
Tape some thin mousing line to the aft end (by the clutch) of the adjacent halliard / sheet. Pull that halliard forwards to the mast so the mousing line emerges under the halliard cover. It will come through the same turning block or diverter as the halliard you have attached it to but with a metal coat hanger shaped like a hook you should be able to fish it back out and round the correct diverter. Then you can use this to pull the main sheet back though
Edited by Matt1 - 01 December 2025 at 07:09
Arcadia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arcadia Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2025 at 15:10
Just a heads up. There may other unseen line guides under the cover which may be missed with this method.
Rear Admiral
Rear Admiral
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2025 at 15:19
Good point! I can confirm on my 418 in a few weeks time as I have to remove the halliard cover to replace the galley window
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ocean Lure Quote  Post ReplyReply Direct Link To This Post Posted: 01 December 2025 at 18:07
Thanks I'll try that and see how it goes
smfree
Cablecar View Drop Down
Lieutenant
Lieutenant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cablecar Quote  Post ReplyReply Direct Link To This Post Posted: 28 December 2025 at 23:37
I have removed the halyard covers on both sides. Not as big a deal as you fear.
Cable Car
Hanse 418 #281
New England
This page was generated in 0.162 seconds.
