Forum Home Forum Home > Hints & Tips > 575/588
  New Posts New Posts RSS Feed - GFCI protection for sockets
Mainer View Drop Down
Lieutenant Commander
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mainer Quote  Post ReplyReply Direct Link To This Post Topic: GFCI protection for sockets
    Posted: 18 January 2026 at 17:59
Hi all,
When I had Bonny Doon surveyed a couple of years ago, the surveyor recommended installing GFCI protected sockets for the head/galley outlets, in-line with ABYC recommendations. I had assumed that the RCBO devices in the AC panel (which the surveyor didn’t notice) would functionally substitute for GFCI but have since learned that GFCI protection kicks in at a lower current (5 mA) than the typical RCBO/RCD (30 mA). Has anyone dealt with this question and gone to the trouble of installing GFCIs?
For reference, Bonny Doon was built in 2015 to US specs (i.e., sockets powered to 120V). FWIW, the boat is in Antigua right now and I’m not — if I were, I’d get a GFCI tester and see if the RCBO trips as expected under a ground fault condition…
—Mainer
Arcadia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arcadia Quote  Post ReplyReply Direct Link To This Post Posted: 18 January 2026 at 19:13
You bring up a good question. On the schematics, the RCBO breakers on the AC switch panel are in fact rated at 30 ma. The good news is they protect the shore power, generator and inverter supplies. A test at the 120 v outlets would be interesting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mainer Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2026 at 11:54
Now that I’m back on the boat, I’ve been able to follow up. Using a standard Klein GFCI tester, the original outlets failed to trip the RCBO breaker. I went ahead and replaced the relevant outlets (those in the heads and the galley) with standard GCFI outlets and now they trip when tested as expected.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arcadia Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2026 at 14:56
Good to know. Question, what style outlets did you use? Standard residential outlets with wall plates ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mainer Quote  Post ReplyReply Direct Link To This Post Posted: 28 February 2026 at 15:46
Yup. According to the surveyor, there isn’t really a ‘marine-grade’ GFCI outlet and he suggested using the standard residential dual outlet + wall-plate setup that one can get at any Home Depot / Lowes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Arcadia Quote  Post ReplyReply Direct Link To This Post Posted: 01 March 2026 at 04:04
Thanks for chasing that issue down.
This page was generated in 0.130 seconds.
