  New Posts New Posts RSS Feed - Watertanksensor
Watertanksensor
Wairua View Drop Down
Lieutenant
Lieutenant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wairua Quote  Post ReplyReply Direct Link To This Post Topic: Watertanksensor
    Posted: 29 January 2026 at 13:06
All,
I have installed a Victron Ekrano onboard to measure also my tank volume a little better.
Already changed the diesel sensor for a Wema and just ordered the watersensor.
The original installed sensor is only 25cm long, while the tank is 33 cm deep. Apart from that, I had difficulties reading the led lights.
The sensor in the watertank is screwed in the tank and not a "VDO connection" type.
For the watertank I just bought a S5 WEMA tanksensor, hoping it will fit in the existing hole and I can mount it with nuts and bolts.
Did anybody already updated it to S5 sensors with VDO connection?
Lieutenant
Lieutenant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wairua Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2026 at 13:13
tango View Drop Down
Commander
Commander
Post Options Post Options   Thanks (0) Thanks(0)   Quote tango Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2026 at 14:04
Mon analyse du capteur de carburant diesel : le fond du réservoir est incliné.
de sorte que les mesures des LED ne sont pas très fiables ;
même lorsque le réservoir est à moitié plein, les LED indiquent qu'il est plein ;
Ouvrez la trappe à carburant et vous verrez par vous-même.
Donc, si la jauge n'est que de 25 cm, il s'agit peut-être d'une marge de sécurité.
Lieutenant
Lieutenant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wairua Quote  Post ReplyReply Direct Link To This Post Posted: 29 January 2026 at 15:00
Thanks for your response tango, indeed the led measurement is not working too well.
The question is: Did anybody install a S5 (WEMA) sensor in the watertank of a 2006 Hanse 370?
This page was generated in 0.083 seconds.
