Forum Home Forum Home > Hints & Tips > 460
  New Posts New Posts RSS Feed - Batten end caps for in mast furling elvstrom
Lhsrris218 View Drop Down
Commander
Commander
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lhsrris218 Quote  Post ReplyReply Direct Link To This Post Topic: Batten end caps for in mast furling elvstrom
    Posted: 20 March 2026 at 21:47
Hi. Only.my second year with the boat but on inspection all my battens had.broken were they join with the composite part.
No problem replacing that but the end caps or tensioners were also broken.
Can't seem to find them online and not course dealer isn't much help.
Any idea where not buy - have contacted elvstrom but no reply.
See attached for part.
marsella View Drop Down
Rear Admiral
Rear Admiral
Post Options Post Options   Thanks (0) Thanks(0)   Quote marsella Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2026 at 22:06
Curious about those battens too, I broke two outer ones, three inner ones are still ok. I guess they break when the sail flaps under strong wind. Mine are 8mm carbon rods from top to bottom, no joints. Let us know if you find the solution. I am personally inclined to get 8mm fiberglass fish tape, fiberglass is softer than carbon, should serve better. Also no need to deal with Elvstrom, Amazon sells those fish tapes 400 feet something rolls for $100.
Rear Admiral
Rear Admiral
Post Options Post Options   Thanks (0) Thanks(0)   Quote marsella Quote  Post ReplyReply Direct Link To This Post Posted: 20 March 2026 at 22:28
End caps - very easy diy, buy 8mm aluminum pipe on amazon, cut to the lenght and close one end, there you get them
Commander
Commander
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lhsrris218 Quote  Post ReplyReply Direct Link To This Post Posted: 21 March 2026 at 23:28
My battens and end caps are 10mm and couple to a rigid carbon fiber piece that's about 5' long.
Im getting new caps made with ss pipe.
How would fish tape work?  Any pointers to product?
Doesn't the sail need the rigidity of 10mm
Rear Admiral
Rear Admiral
Post Options Post Options   Thanks (0) Thanks(0)   Quote marsella Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2026 at 00:10
Fish tape is a wire puller made of fiberglass, you can check it here
https://a.co/d/08dNbL1G, i think they also have it in 10mm. My carbon battens are 8mm and I am missing one right now, maybe 8m long, hence I was thinking to use fiberglass rod instead. If you broke your 5' carbon batten where did you get the replacement? I can find carbon rods but nobody sells them longer than a meter in lenght, and I need 8m.
Commander
Commander
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lhsrris218 Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2026 at 00:24
The carbon rods are ok.  It's the fiberglass portion that broke 10mm x 47 feet
Rear Admiral
Rear Admiral
Post Options Post Options   Thanks (0) Thanks(0)   Quote marsella Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2026 at 00:49
Ok maybe that wire puller is the solution for you. I tried to connect a few carbon rods 1m each with 8mm aluminum tubing to make a long batten but this one broke right at the connection point after a few sails therefore im thinking it has to be uniform over the whole lenght. Im going to try this 8mm fiberglass rod, at least its cheap, widely available and i can carry the whole 150m roll in the airplane...
Commander
Commander
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lhsrris218 Quote  Post ReplyReply Direct Link To This Post Posted: 22 March 2026 at 13:16
Looked a bit more into the wire puller.   Not very rigid so don't think it is appropriate.
Looks like a flexible glass fiber core wrapped with an outer cover.
Need something solid.
This page was generated in 0.094 seconds.
