  New Posts New Posts RSS Feed - Volvo MD2010
Volvo MD2010
Richard Harper View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richard Harper Quote  Post ReplyReply Direct Link To This Post Topic: Volvo MD2010
    Posted: 12 December 2009 at 21:07
I'm just back from another fantastic sail on our Hanse 301 Swn Y Mor but when we were motoring back in the engine died back down to about 1000rpm. It didn't stall & got us back fine. But every time I put it back in neutral & then up to about 3000rpm to motor it quickly dropped back on its own to very low revs.
Has anyone ever had anything like this or any idea what it could be?
greyghost View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote greyghost Quote  Post ReplyReply Direct Link To This Post Posted: 13 December 2009 at 03:31
Richard,
This sounds like a fuel starvation issue. Check (or replace) your engine mounted fuel filter, check (or replace) your in-line fuel filter (Hanse seem to use the Bosch as standard). Before you do any of this, however, you might check to make sure that any valves between the fuel tank and the engine are clearly in the 'open' position.
It's also possible you may have wrapped something around your prop or, if it's a folding version, it may not be opening properly. If either of these were to be the case, however, you'd likely be noticing a fair bit of vibration, which you did not mention. So, more likely a fuel starvation issue.
Doug
Doug
Grey Ghost 342 #405
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richard Harper Quote  Post ReplyReply Direct Link To This Post Posted: 13 December 2009 at 07:26
thanks doug - what you say seems right I'll try those things first (there was no vibration)
Richard
panos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote panos Quote  Post ReplyReply Direct Link To This Post Posted: 13 December 2009 at 14:21
It looks that the engine is starving in high revs only.
This can happen if the fuel/water separator is almost full with water and the protection valve is almost closed. Bleeding the water out of the separator will resolve the problem (with the engine off).
Panos
Hanse 630e - selling her -
holby View Drop Down
Admiral of the Fleet
Post Options Post Options   Thanks (0) Thanks(0)   Quote holby Quote  Post ReplyReply Direct Link To This Post Posted: 13 December 2009 at 20:50
If it were me I would also check the water separator a Panos suggests. I had a water problem early spring this year.
Ps Where do you, Richard, sail out of?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richard Harper Quote  Post ReplyReply Direct Link To This Post Posted: 13 December 2009 at 21:41
cheers holby & yes I'm going to empty out the fuel seperator as well as the filters. We sail at Thornbury Sailing Club which is on the south side of the severn estuary.
all the best
richard
Post Options Post Options   Thanks (0) Thanks(0)   Quote holby Quote  Post ReplyReply Direct Link To This Post Posted: 13 December 2009 at 21:55
ah, I may see you sometime next year as sail my 301 at Barmouth in the summer months but i will be taking 12 months at cardiff marina,from april next year, but also keeping Barmouth mooring going as well.
Edited by holby - 13 December 2009 at 21:56
samuel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote samuel Quote  Post ReplyReply Direct Link To This Post Posted: 14 December 2009 at 07:50
Richard
Similar thing happened to me
It was diesel bug in the fuel clogging the fuel line
I flushed some of it out then used a bug inhibitor & ( touch wood) have not had a repeat . It looks like a black jelly.
I add the inhibitor at end of each season & fill the tank to avoid condensation
It seems to do the trick as I do not add it very often.
echoofwight View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote echoofwight Quote  Post ReplyReply Direct Link To This Post Posted: 15 December 2009 at 08:54
Hi Richard,  as already said change the filters,  you need to take them off to check so may as well change them.  If you the primary is the volco glass bowl type (mine is) you can drain water out of the bowl, but the filter itself may be clogged up.  Can get a bit messy changing the primary, depending on where it is located.   I change both filters once per year.
papagayo View Drop Down
Lieutenant
Lieutenant
Post Options Post Options   Thanks (0) Thanks(0)   Quote papagayo Quote  Post ReplyReply Direct Link To This Post Posted: 16 December 2009 at 14:46
Dave,
I think Bovine has his 430 in Cardiff. You should go and buy him a drink. Smile
Happy sailing. [IMG]smileys/smiley1.gif" align="middle" />
This page was generated in 0.086 seconds.
