  New Posts New Posts RSS Feed - Aligning Fluxgate Compass
tony1 View Drop Down
Lieutenant
Lieutenant
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony1 Quote  Post ReplyReply Direct Link To This Post Topic: Aligning Fluxgate Compass
    Posted: 24 March 2012 at 10:49
I have replaced the erractic and now dead Simrad wheelpilot on my 315 with a Raymarine SPX-5 wheelpilot, and now have 3 compass readings - the boat compass, the chartplotter, and the fluxgate display.  The Simrad WP of course had a fluxgate compass, but no display.  The boat compass and the GPS have always been about 10 degrees different.
So my question now is which compass to align the Raymarine fluxgate with?  If I align it with the boat compass, at least I'm looking at compatible information.  But if I want the wheelpilot to steer to a waypoint, the GPS is telling it where to go and if it's not aligned with the GPS, it won't know exactly where to steer.  Or is there some self-correction software at work?
panos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote panos Quote  Post ReplyReply Direct Link To This Post Posted: 24 March 2012 at 13:28
There is a difference between magnetic North pole and the geographic Earths North pole.
The magnetic compass aligns itself to the earths magnetic field and always shows to the magnetic north pole (of course needs calibration to compensate the disturbance by heavy metal objects. Mainly the engine)
The fluxgate compass reads also the magnetic field. By turning the boat at a constant speed it calibrates itself, but has no way to know where is the Magnetic North direction. You need to enter the Magnetic North direction - align it to the boats compass!
The GPS does not work by the magnetic field. It reads the distances from satellites orbiting the earth and calculates the position by trigonometric calculations. The direction it shows is the geometric - TRUE NORTH .
In some lucky places -like Europe for example- the difference between True North and Magnetic North is just a few degrees and can usually be ignored for short passages.
The above is not true everywhere! There are some places on earth where the magnetic field is so disturbed that the magnetic North direction shows to the Earths South Pole! Extreme care is needed to navigate in these places.
Check to find the local magnetic declination before calibrating the compasses. For your safety you need to be able to navigate without the help of the GPS, just in case!
http://upload.wikimedia.org/wikipedia/commons/d/d4/World_Magnetic_Declination_2010.pdf
Edited by panos - 24 March 2012 at 13:37
Panos
Hanse 630e - selling her -
echoofwight View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote echoofwight Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2012 at 13:59
Hi Tony,  where do you sail,  if like me you are on the UK south coast the difference is about three degrees.  I aligned my SPX-5 by using the GPS reading but you need to be in slack water and traveling faster than about three knots.   GPS shows the boats direction of travel. Ships compass shows the way the boat is pointing.  These are often different especially in tidal streams.
Lieutenant
Lieutenant
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony1 Quote  Post ReplyReply Direct Link To This Post Posted: 28 March 2012 at 18:07
Hi Steve - I sail from Buckler's Hard.  Where did you instal your fluxgate compass?  Mine is (so far) in the front cabin - as far away as I can get it from loudspeakers etc.  I thought I had it aligned to the boat compass, but discovered yesterday that it is accurate on port tack, and about 40 degrees out on starboard tack! Perhaps alignment to GPS would be better - I take your point about cross-track error.
Post Options Post Options   Thanks (0) Thanks(0)   Quote echoofwight Quote  Post ReplyReply Direct Link To This Post Posted: 30 March 2012 at 08:28
Hi Tony,  I sail out of Portsmouth Harbour.  I like Bucklers Hard it must be a great place to sail from.
 My fluxgate compass is below the bunk in the forcabin.  So far this has worked great.  Overall I have found the SPX-5 an improvement over the simrad WP20 that I did have.  I have in fact changed all the instruments from Simrad to Raymarine.
I don't understand the diference on port and starbord tack,  is the fluxgate mounted facing for and aft and upright.  Or is the ship compass diferent on for and aft.
Goodie View Drop Down
Lieutenant
Lieutenant
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goodie Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2013 at 01:57
Can someone advise me on where I can expect to find the fluxgate compass (I think it is the RC36 model) on my 2007 Hanse 370. It was installed by Hanse at their factory when they installed my Simrad AP 25 auto pilot at the  time they built the boat. I have traced the wire for the fluxgate compass from the AP 25 auto pilot in the cockpit along the port side to the bulkhead separating the forward cabin from the main salon. Presumably it should be centred (or near the centre line of the boat) and I would assume somewhere low in the forward cabin, perhaps below the birth?  My thanks.
Goodie
Karinya
Hanse 370 #251
Goodie
370 #251
This page was generated in 0.082 seconds.
