  New Posts New Posts RSS Feed - What is the best autopilot for a Hanse 320?
 Post Reply Post Reply Page  <12
Louba View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Louba Quote  Post ReplyReply Direct Link To This Post Posted: 11 February 2018 at 20:31
Dear Claude.
Thank you very Much.
Louba of Marseille
pirat
mystudio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mystudio Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 08:37
I'm fitting my 320 also with a DD1 drive. However, it seems to be impossible to apply the 106mm offset Jefa is talking about. Does anyone have experience with this? Mounted it in other ways which also work? Please, let me know if you do (or don't). Thx in advance.
iemand View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote iemand Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2018 at 09:11
Alu van consider a sd10 Drive instead.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Louba Quote  Post ReplyReply Direct Link To This Post Posted: 04 June 2018 at 10:44
Voilà le nouveau pilote est installé.
My New autopilot is installed.
Louba
Post Options Post Options   Thanks (0) Thanks(0)   Quote Louba Quote  Post ReplyReply Direct Link To This Post Posted: 06 June 2018 at 07:43
Post Options Post Options   Thanks (0) Thanks(0)   Quote Louba Quote  Post ReplyReply Direct Link To This Post Posted: 06 June 2018 at 07:47
In the previous post, a picture of the installation of Autopilot JEFA in my H320. It's coupled  with Raymarine electronics.
Louba
Edited by Louba - 06 June 2018 at 07:48
Brufan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brufan Quote  Post ReplyReply Direct Link To This Post Posted: 06 June 2018 at 15:40
Louba,
Le cable de mise à la terre de la mèche de safran doit être enlevé suivant la note de JEFA.
Mon bateau avait fait l'objet d'un "rappel" à ce sujet.
Bruno
hanse 355 - 57
S/Y Spicy Ginger
Post Options Post Options   Thanks (0) Thanks(0)   Quote Louba Quote  Post ReplyReply Direct Link To This Post Posted: 06 June 2018 at 16:00
Bonjour Bruno.
Merci pour l'information. Est-il possible de me faire passer cette note? Nous n'avons rien vu dans les documents d'installation.
Je voudrais en informer mon installateur.
Et où doit-on relier le câble de mise à la terre?
Olivier (Louba)
aquilo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote aquilo Quote  Post ReplyReply Direct Link To This Post Posted: 12 June 2018 at 19:05
Hi. I am installing the Ev100, instruments and controllers installed OK on to the simnet bus. But I struggle to find where the autopilot circuit +12V cable from the breaker panel goes. It is rather thick and color is magenta, but it sees to "disappear" into a black hole. Not able to locate where it ends, even after several hours searching.
Any suggestions?
Edited by aquilo - 12 June 2018 at 19:38
Hanse 320
Norway
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brufan Quote  Post ReplyReply Direct Link To This Post Posted: 14 June 2018 at 17:45
Il s'agit d'une note de JEFA émise lorsqu'ils ont appris que Hanse raccordait la mèche alu à la 'terre' du bateau.
Il y a un risque renforcé d'électrolyse de la mèche.
Il faut simplement la déconnecter de la mèche (un coup de pince coupante...) et ne la raccorder à rien.
(certains craintifs font pendre une anode au port directement raccordée à la mèche ; un peu comme sur les bateau en alu)
Bruno
hanse 355 - 57
S/Y Spicy Ginger
